Lawn Ranger Tomfoolery
Author Message ranch king pro 08 Established Member
2023 Build-Off Top 3 Winner
Age : 24Join date : 2024-02-20Points : 629Posts : 327Location : South georgia Subject: Re: Lawn Ranger Tomfoolery May 26th 2024, 6:40 am ranch king pro 08 wrote: Me want grippy rubber rings me get no rubber rings me get angry Lol. RKP SMASH!!!!
Like 1
RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 26th 2024, 6:18 pm Just about done, just gotta tap a set screw hole or two.
Like 1
MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma Subject: Re: Lawn Ranger Tomfoolery May 26th 2024, 7:28 pm Nice job! Take any damage in your area from storms?
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 26th 2024, 8:48 pm Not more than a few branches down here…heard Russellville had it a bit worse.
AYO!! Hammered the hubs on the axles(someone misjudged the keyway depth) and let about 30psi out of these tires. Left them at 5psi and I cannot believe how soft they are at such high pressure!
Sort of undecided on the rim width situation at the moment…not sure I want to lose the height to flatten the tread profile out. I’ll have to see if it still floats over mud like it did with the knobbies. Don’t seem to have an issue with rims spinning either, so bead locks might wait a bit.
Oh and I drilled out the old tires to 4x4.
Like 2
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 27th 2024, 6:28 pm Storms knocked the power out last night. Lawn ranger makes a decent angle grinder in a pinch
Semi-paddle tires still soft enough to work good on rock! Seem to perform good in deep mud as well, I skated over some right after this
MightyRaze, ranch king pro 08 and Ifitaintbroke like this post
Like 3
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma Subject: Re: Lawn Ranger Tomfoolery May 28th 2024, 12:07 am Nice! Love it when people think outside the box.
Like 1
Ifitaintbroke Member
Age : 24Join date : 2024-02-20Points : 629Posts : 327Location : South georgia Subject: Re: Lawn Ranger Tomfoolery May 28th 2024, 6:54 am MightyRaze wrote: Nice! Love it when people think outside the box. Rich apparently doesn't have any boxes. It's kinda scary sometimes.
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 28th 2024, 1:17 pm I kinda just do whatever I guess I need to put a little bumper on this thing.
MightyRaze and Ifitaintbroke like this post
Like 2
Age : 24Join date : 2024-02-20Points : 629Posts : 327Location : South georgia Subject: Re: Lawn Ranger Tomfoolery May 28th 2024, 4:05 pm RichieRichOverdrive wrote: I kinda just do whatever I guess I need to put a little bumper on this thing. Wish I had the tools and skills that you do. I come up with some pretty crazy stuff. Like a v-twin made from a cut-up 460.
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 30th 2024, 12:26 am Out causing trouble like usual. I actually did pour some motor oil in the trans the other day as I think most of the oil had leaked out.
VIDEO The belt is kind of getting worn and starting to do weird stuff. Used to, whenever the belt was pulling the trans pulley was moving with it, now the belt will slip at the engine under lighter load and then start to slip at the trans when it’s loaded up and lugging the engine. Kind of weird. The clutch still hooks good though, just that the bite point of the clutch pedal is higher when the belt is hot and under load.
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 30th 2024, 11:13 pm Lawn ranger got a bumper! Just an addition to the engine cage really.
Believe it or not I actually couldn’t make it any wider without hitting the tires. These wheel horses turn super sharp!
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma Subject: Re: Lawn Ranger Tomfoolery May 30th 2024, 11:49 pm RichieRichOverdrive wrote: Believe it or not I actually couldn’t make it any wider without hitting the tires. These wheel horses turn super sharp! I ran into the same issue. That's why mine is narrow too.
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 31st 2024, 12:18 am As long as it keeps trees out of the grille I guess. Though it’ll probably find more use as a handle on this rig. I usually just manhandle it out of situations I can’t drive out of.
Took it out and bonked the bumper on some trees, it’s plenty solid. Can stand on it without it flexing too, that’s the test I go to for a lot of my stuff.
Front of the trans mount is looking lovely. I do tend to slam it into stuff a lot. I think I have brought the tractor to a complete stop in 3rd gear by slamming the trans mount into a rock ledge, might explain why the ears of it are completely folded over.
Age : 49Join date : 2016-09-06Points : 15678Posts : 10988Location : Oklahoma RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery May 31st 2024, 12:41 am I did one for the 414-8. I need to make a sort of lightened version for this, while preserving as much clearance as possible.
Guess I never actually posted pics of the hubs on the tractor.
One of these days I’ll go back to painting stuff instead of just throwing it together and using it
Ifitaintbroke likes this post
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 1st 2024, 10:18 pm Plastic idler pulley is just barely holding in there
printing another one now
Like 2
Age : 24Join date : 2024-02-20Points : 629Posts : 327Location : South georgia RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 2nd 2024, 11:51 am Mostly because I don’t think I have a chunk of aluminum that big at the moment lol. These work pretty good really and don’t take any effort to make.
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 5th 2024, 9:47 am Ok, last pulley i swear
I realized that having my clutch spring hooked at the stock spot over the axle kind of makes the brake band drag, so I made this like….uhhh….clutch spring adjuster thingy.
@Hot Lap described it best, he called it “ghetto”
it’s the same material as my wire belt guides. Can move the clutch spring around on it for different tension.
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 8th 2024, 10:55 pm Made an adapter for the indestructible craftsman steering wheel
Just kinda copied the funny drive shape and snuck up on it with cutter comp so the wheel fit good and snug.
Sure looks wrong! But I guess that’s the price to pay for durability.
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 9th 2024, 12:46 pm I mean, I don’t know that they’re truly indestructible, however the one on mutt has been under the tractor every time it rolled and never broke or anything, just got some extra texture from getting scraped over rocks lol. This one I robbed off the GT6k and it has been under that tractor a time or two as well
Like 1
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 17th 2024, 1:31 pm Lawn ranger did great at Haspin.
Think this was from a video
@mr.modified took
Just about all of
@MightyRaze s rigs in one pic here with the lawn ranger
Last edited by RichieRichOverdrive on June 17th 2024, 11:53 pm; edited 1 time in totalMightyRaze, ranch king pro 08 and Ifitaintbroke like this post
Like 3
Age : 22Join date : 2016-10-29Points : 7224Posts : 4021Location : Lewisburg, KY Subject: Re: Lawn Ranger Tomfoolery June 17th 2024, 11:51 pm Oh yknow. That makes more sense considering you’re in the picture
I guess I was thinking of another picture
