 Project VAP Off-road logger
Threewheela
TechnoChicken
BairleaFarm
Hammernco
11 posters
Hammernco
Project VAP Off-road logger - Page 2 Empty
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 21st 2023, 11:58 am
Got some front end reinforcement done during lunch, basically fully welded the stock axle, fixed the play in the spindles bores and beefed up a bit the soon to be non bolt on craddle!
Didn't go for a a whole lot of flex, it should be sufficient!
Also tried to find the exact power output of my engine googling the engine codes but no luck..
If any of you know I'll be glad to know if it's a 13.5 or 15hp?
Project VAP Off-road logger - Page 2 Img_2018
Project VAP Off-road logger - Page 2 Img_2019
Project VAP Off-road logger - Page 2 Img_2017
More to come tomorrow!
Cheers!
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 21st 2023, 12:30 pm
A 28ci could be anywhere from 13 to 19hp I believe, it depends on the carb model, am I correct to assume it has a Walbro? I want to say WT54 would be a 18hp model but it's been months since I researched it all so I could be wrong.
My All Terrain Tractors:
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 21st 2023, 12:37 pm
Nice welds on the axle reinforcement.
You have a 28 cubic inch sleeve bearing engine built in 03. It's either a 12, 13, 14 horsepower.
Hammernco likes this post
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 21st 2023, 5:18 pm
The 28ci OHV I had was a 14.5. All of the 31ci engines I had were 17.5hp. Pretty safe bet that yours is a 14.5.
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 22nd 2023, 3:22 am
Thanks for chiming in, will have a look at the carb to find out, boy it is hard to find infos on those engine !
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 22nd 2023, 3:25 am
Hopefully, but being a european model, might be a smaller power output, europe is gready in terms of HP! LOL.
So if I understand well, the HP output is based on the carb only ?  all the 28 CI share the same engine?
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 26th 2023, 8:11 am
A bit of update since I had a little bit of time to work on the mower.
The front end is back in fully welded with 10 degrees of caster, steering is back and lengthened to accommodate the new wheel base. Slight problem I spotted, bumpsteer, figured I will address this matter if it really borther when ridding.
About to fuse the rear transaxle in for good next week but before, I would like to know how much slack is a good belt slack for clutch disengage?
Is there any rule of thumb?
Should the belt be able to be removed from pulley when clutch push in?
Any Infos would be great Grin.
Thank you guys!
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 26th 2023, 11:07 am
Big thing is make sure your belt is snug when no clutch and not necessarily fall off when clutched.  Belt guides are 100% needed to make sure your belt disengages well.  Should your belt sag quite a bit, some kind of J hook style guide or one of those twist guides will help A LOT! Placed at the center of the sag.
Project VAP Off-road logger - Page 2 Hus-5310
Project VAP Off-road logger - Page 2 51kifu10
Project VAP Off-road logger - Page 2 Sig115PROJECTS:
Project VAP Off-road logger - Page 2 Sig214Project VAP Off-road logger - Page 2 Sig314
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 26th 2023, 11:41 am
I have ran clutches at varying slack, Mutt's currently has just enough slack for you to pop the belt off of the engine pulley. On that setup I had to add lots of keepers to centralize the slack around the engine and transmission pulleys, so the belt disengages from them. On the other hand, the GT6k has tons of slack with the belt pushed in and took just a few belt keepers to make work. I think Budgie was the same way, tons of slack and just a few keepers.
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 26th 2023, 3:35 pm
Well noted Mighty.
I have some of the stock ones that I can manage to move around finding the best spot.
So you think I should weld the transaxle in place when the belt is snug clutch out and work on the clutch mechanism to get the needed slack to desengage?
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 26th 2023, 3:38 pm
Thanks for the input Richie, guess it will take a bit (hopefully) of trial and error but with yours and mighty advise I hope I can make it to work decently first time.
More update next week guys!
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 28th 2023, 8:09 am
Hi Guys, got the clutch I believe sorted out, belt tension seems fairly tight when clutch is out and motor pulley spin freely when clutch is pushed in.
Got a few more things to do before test run but feel quite confident about that clutch deal.
Tried to follow the given advises, thanks again for the guys that chimed in 😊.
Here are the pictures of the set up
Project VAP Off-road logger - Page 2 Img_2021
Project VAP Off-road logger - Page 2 Img_2022
Project VAP Off-road logger - Page 2 Img_2020
Let me know if you see anything that may cause some troubles
Thanks
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 28th 2023, 12:28 pm
The only potential problem I see is how the idler near the engine pulley is pulling the belt away from the pulley but if it doesn't cause belt slip then it's not an issue! If it does you'll want to try and move it more towards the center of the machine
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 29th 2023, 8:03 am
You are right that I llok at it, this is the way it is made from factory only difference is a smaller engine pulley.
Will see what it does, if it goes to sh*t, then I'll correct it following your instructions but will have to rethink the relaease mecanism to invert the way it fonctions Sad
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 29th 2023, 10:40 am
Actually that is how many Engine side clutches work.  Engine pulley turns CCW (Looking from the angle pictured).  While it appears to pull the belt away, it is actually drawing the belt in on the pull side.  When clutch is pushed in, that tension is released from the pull side allowing the belt to slip.
I hope that made sense.
Sears Craftsman/AYP/Roper has used this same path for decades.   (Look at a sears suburban, same path just for a horizontal engine)
Look like the images above?
Project VAP Off-road logger - Page 2 St16_b10
Brianator and Hammernco like this post
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 29th 2023, 10:55 am
All good then! Can't wait to test ride and revert back!
Thanks for your input
Headcase
Headcase
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 29th 2023, 2:18 pm
Tires look bada**
TechnoChicken
TechnoChicken
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 29th 2023, 5:32 pm
Headcase wrote:
Tires look bada**
badash is how we say it round here Wink
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 30th 2023, 3:03 am
Headcase wrote:
Tires look bada**
I tried to look for the best shaped and cheapest deals I could find used!
Of course, I looked for the sizes first, 19 fronts and 22 inches in the back.
Eager to find out if traction will be good for my needs with those Bear claws in the back.
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeNovember 30th 2023, 9:09 am
Started on the frame reinforcement using some rectangular tubing I had laying around.
I split it in half as I only had a short piece in hand.
It stiffen the flimsy stock frame quite a bit already and I'm not done yet, still need to build a piece to join the two rail at the back in order to mount the rear fenders and seat and also find a way to make it strong enough to build the hitch and future accessories off of it.
Frame as I got it
Project VAP Off-road logger - Page 2 Img_2023
Side raiils fuse over the existing
Project VAP Off-road logger - Page 2 Img_2025
Project VAP Off-road logger - Page 2 Img_2024
More to come probably tomorrow.
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 8:04 am
Good step forward, I can now sit on the darn thing! Project VAP Off-road logger - Page 2 Img_2027
Project VAP Off-road logger - Page 2 Img_2026
Clutch pedal is now made to my liking, need to work on the shifter as neither one fit or shift nicely as is!
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 5:09 pm
That frame is looking real stout! I think you will need some belt supports along the belt there to keep it from sagging. Or maybe you can do a belly pan, that would be cool!
PizzaKitty26
PizzaKitty26
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 5:17 pm
Wow, nicely done, those welds look great, that Stick? We will not talk about my welds, lol yours look great!
PizzaKitty26
PizzaKitty26
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 5:19 pm
Also you weld those rear rims on? lol!
TechnoChicken
TechnoChicken
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 5:22 pm
People in glass houses shouldn't throw stones, I personally welded the ones on your rig and they seem to hold up well decent option compared to the expensive one which is buying hubs. And WAAAAAYYYY better then welding the hubs direct to the trans, that is an outright sin in my book
PizzaKitty26 and Hammernco like this post
Hammernco
PostSubject: Re: Project VAP Off-road logger   Project VAP Off-road logger - Page 2 Icon_minitimeDecember 1st 2023, 7:15 pm
Thaught about doing one, depends on the material I have in hand and how the belt does once I ride it
» John Deere 112, Off Road Racer/Mudder Project
» Craftsman Rider 15 HP Kohler Off Road Project Build on Youtube!
» Kubota Off-Road Lawn Mower Complete Restoration Project - another country
» Off road MTD
» off road pics of the day :)
