I'd imagine it has a vertical shaft engine yes? If so it's going to be tricky to go from vertical to horizontal for a live axle, not impossible (nothing is impossible) but it won't be cut and dry I can tell you that! It could be simplified by using a Peerless 700 transmission (it has a vertical input and a horizontal ouptut) IF you could get your hands on one, it's a pretty popular part in the mower racing community so it might not be easy to track one down.
What happened to the trans? If the input gears and case are still intact here's an option for you, this is something I'm planning on doing myself.
Considering I don't have any first hand experience that's probably all I have to offer, hopefully someone else has some info for you!
@Brianator I truly appreciate the advice. I planned on using a predator 212 I have just because it's just sitting around and it's nearly brand-new. I also already have a live axle that should work (in Theory) lol
Brianator Moderator
Are you talking a fixed axle? Or a floating/swingarm/leafspring suspension? Technochicken built a golf cart with the stock leaf spring suspension on it and just bolted the pillow blocks to the leaf springs and put the axle thru them, mounted the motor were the batteries normally are. What happened is every time you hit the gas to hard or went over a bump, the chain went slack and it fell off. My personal recommended path for you would be to mount the motor on a platform mounted to the axle with pillow blocks, then add suspension. Sounds like this machine is going to be pretty cool btw!
ranch king pro 08 Established Member
2023 Build-Off Top 3 Winner
Age : 16 Join date : 2023-06-01 Points : 1171 Posts : 570 Location : East Texas
