 Engine mount
Normandybrit
Engine mount Empty
PostSubject: Engine mount   Engine mount Icon_minitimeAugust 3rd 2023, 5:48 am
I'm slowly making way with putting a 16hp Vanguard motor into a mid 80's MTD. When I pulled out the old 11hp motor I found it had a rubber mounted plate under the motor. First I'd come across (see picture). Is there any advantage in using this?Engine mount Yp_bot11
Engine mount Empty
PostSubject: Re: Engine mount   Engine mount Icon_minitimeAugust 3rd 2023, 9:12 am
Help reduce vibration from the engine to the mower. No need for it. Up to you.  It was common.  My Halloween display tractor has one on it's engine from the 70's.
Engine mount Sig115PROJECTS:
Engine mount Sig214Engine mount Sig314
Engine mount Empty
PostSubject: Re: Engine mount   Engine mount Icon_minitimeAugust 3rd 2023, 9:44 am
I replaced the rubber isolators with G10 fiberglass sheet material that I custom cut, not only are they difficult to find but they're expensive when you do.
My All Terrain Tractors:
Engine mount Empty
Engine mount
» Honda HT-R 3009 mid engine rider engine swap
» Just wondering if anyone has ever tried to mount a blade to a lawnmower?
» Where to mount a gas pedal on a wheel horse
» How to mount hand crank winch?
