Been working on this little gem for almost a year now. Just about finished. It all started with a free MTD tractor which I removed all the vari-drive workings and gearbox from. The tractor became my trail runner which can be found here: http://atltf.forumotion.com/t33-mtd-trail-runner-build
The beginning of the frame consists of 1"X1" square tubing. Used the stock axle from the tractor so it will have a single forward speed as well as reverse.
This picture shows the engine and fender mock up. Used the fenders off another MTD tractor. These ones were much heavier than what came on the tractor the axle came out of. The engine will be a 3.5hp Briggs and Stratton classic of a Dynamark push mower.
ferg Member
Join date : 2011-10-24 Points : 4820 Posts : 45 Location : Cheshire, England
you might want to rethink the angle on the clutch cable. I have found that the cables wear out real quick on anything but a straight pull. hard pulls will yank the barrels off them too
Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5471 Posts : 84 Location : Nova Scotia, Canada
It's been working fine for a year now, but I would really like to upgrade to a brake cable off a quad or motorcycle. I had to run the cable so tight to get enough travel to release the belt from the pulleys.
redneckandy New Member
Age : 28 Join date : 2011-07-05 Points : 4904 Posts : 12
it is looking really good but I think If you could get a back wheel for the front it would perform and look better , those 3.5hp briggs have plenty of power once the govener is removed and a straight pipe is fitted
MSteele323 Member
Age : 50 Join date : 2010-04-09 Points : 5704 Posts : 267 Location : Little Rock Arkansas
Pretty cool - be easy to do upgrades now that its done.
One thing tho - the forks seem like they could be leaned back just a bit- looks like itd flop over if it hit something on the front wheel hard enough - they seem too 'straight' up and down.
Jamus Established Member
I don't suppose you could get a better shot of the foot shifter? I asked on one of your youtube videos since I'm having problems with getting on this forum at home.
