 Bandbrake Repair - Re-line
5 posters
Bandbrake Repair - Re-line Empty
PostSubject: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 3rd 2023, 1:02 am
#bandbrake
Brake material I have used on the now 4 times with 100% success:
McMaster-Carr (6175K811)
McMaster-Carr
Metal-Free Brake and Clutch Lining
I believe 1 foot is good, should give an inch or two extra to be cut off.
I used JBWeld with the red label, not the yellow.  It's supposed to be stronger and just basically glued it on while clamping it overnight.  The first one I did was nearly 6 years ago and is still holding like the day I put it on, stops great too!  The other 2 are just the same.  Heck, I did it with the brake shoes on my peerless 2300 and it works great too.
Sears Suburban
Bandbrake Repair - Re-line Img_2436
Craftsman GT6000/ Craftsman GT18 I did, pretty much the same as well:
Bandbrake Repair - Re-line Img_0151
As I mentioned, I did some brake shoes with the same stuff with just as good results.
Bandbrake Repair - Re-line Img_0268
Bandbrake Repair - Re-line Img_0267
Bandbrake Repair - Re-line Sig115PROJECTS:
Bandbrake Repair - Re-line Sig214Bandbrake Repair - Re-line Sig314
Brianator and JB_4x4 like this post
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 3rd 2023, 8:37 pm
I should try and reline the pads on the 633 in the GT6k with this stuff. If ever I put that trans back together.
Okie743
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 13th 2023, 8:37 pm
Good info.
Thanks
Ifitaintbroke
Ifitaintbroke
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 7th 2024, 9:27 pm
I'm hoping there is a cheaper solution to this, as the material linked above is currently at $52.65 for 15 inches. No longer sold in 12 inch lengths.
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 7th 2024, 10:19 pm
I believe you are looking at 15ft rather than 15 inches. Check the description. seeing $3.51/ft here.
JB_4x4 likes this post
ranch king pro 08
ranch king pro 08
2023 Build-Off Top 3 Winner
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 7th 2024, 10:26 pm
Yep you're right if you scroll over to the last picture it gives you full dimensionsBandbrake Repair - Re-line Screen29
Ifitaintbroke
Ifitaintbroke
PostSubject: Re: Bandbrake Repair - Re-line   Bandbrake Repair - Re-line Icon_minitimeMay 8th 2024, 8:10 am
Man I'm dumb. Thanks guys!
» Single line/ double line Brakes?
» axle repair help
» Go Kart Repair For Re Sale
» Yanmar 135D Repair
» T-Dub's Tire Bead Repair
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
