| '68 Cub Cadet 125 "Kronos" | |
Mrbrucie22 Member
Age : 34 Join date : 2022-11-26 Points : 826 Posts : 72 Location : Glasgow KY
| Subject: '68 Cub Cadet 125 "Kronos" January 4th 2023, 4:19 am | |
| Decided to go ahead and start the build thread for the 125 cub we are calling "Kronos" (kinda sticking with the wwhole greek mythology names) This was the very first tractor I got from my father in law and initially I was going to use it for an offroad mower and swap in a geared transaxle but I have decided that it would be a good idea to have a stout utility setup to do work around the house. It is a hydro and has the stock 12hp Kohler k series engine. That being said, I now plan to keep it pretty much stock and use it as it is. As far as i know, it's only missing the starter/generator and a seat but i believe those parts are still out at the in laws. I plan to keep this build simple to start and getting it running is first priority. This will be a back burner build for those days I'm not working on the build off mowers. Should be fairly simple to get any parts I may need because the in law used to build cubs for sled pulling and has cub parts all over his property. It ran less than 3 years ago when it was parked but has been sitting out in the elements uncovered since. It spent many years at the pulling track to level the strip and pull breakdowns off the track. This it how I found it when I went to pick it up. And this is where it sits now next to the shop | |
| | | | Mrbrucie22 Member
| | | | AllisKidD21 Moderator
| Subject: Re: '68 Cub Cadet 125 "Kronos" January 4th 2023, 1:36 pm | |
| Nice tractor, can't beat the narrow frame Cub's! I've got a 106 and 124. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 97 users online :: 0 Registered, 0 Hidden and 97 Guests
