 Murray Hydro Widebody
2 posters
Murray Hydro Widebody Empty
PostSubject: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 1:13 am
First off, the model sticker is missing so I don't know what year it is.  I'm guessing around 1999ish.
The engine pulley is loose and only held on by the belt.  I removed the pulley bolt and it easily slides up and down.  Some surface rust underneath, nothing too bad.  Looks to be pretty solid. It has all the provision holes for a geared trans. That is great!
Here is the kicker.  Do you see what I see? @murraymountain may see it. 2 things in particular.
Murray Hydro Widebody Img_1224
Murray Hydro Widebody Img_1223
I'll tell ya tomorrow late morning here what I see.
Murray Hydro Widebody Sig115PROJECTS:
Murray Hydro Widebody Sig214Murray Hydro Widebody Sig314
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 10:10 am
Yup, sure do! Want me to name 'em or let someone else have a go at it? lol
So I'm a little confuzled here... is this tractor going to be a build or a parts tractor?
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 11:05 am
Go ahead and name them.  Murray Hydro Widebody 2731072446  This tractor will be a little of both probably.
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 11:15 am
1, factory idler that allows the belt to be ran by the steering shaft without needing to pull it for belt changes. 2, factory double pulley clutch.
Also, did you say the hydro was bad in this tractor, or is that still TBD?
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 11:52 am
Like I figured.  You nailed both of them. afro
Factory double clutch is fine, but that bracket with idler to move the belt around the steering is pretty big.  Although with a larger engine pulley may be an issue. LOL.
Murray Hydro Widebody Img_1225
Murray Hydro Widebody Img_1226
It (hydro) is still to be determined.  I think the initial issue I seen, is a rusted-up brake.
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 12:51 pm
If the trans is good and you don't do anything with it, we might be able to work something out whenever we end up at Haspin at the same time or something... I need an extra trans in case I screw one of Ole Blue's up Murray Hydro Widebody 1098998679
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 1:52 pm
I know Haspin isn't in the cards for me this year. We have other obligations that will keep us tied down for the months of June and July. :-( 2024 we have tentative plans. I'll hang onto it should it work.
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 4:57 pm
OK, stripped down quite a bit. It's going down to rails eventually. I'm stopping for now. Front half of the frame is excellent shape. Back where the transaxle is... well it's had a dose of battery acid it wanted to bathe in. When I get it to rails, I'll see how bad it really is.
Hydro trans. I put the drill to it. After a few seconds it seemed to come to life. Now there is no hesitation and seems to work very well. Should I not need it in the next year, I don't see any reason to hand it off @murraymountain. It'll just be a matter of life not throwing curveballs to keep that from happening.
As I suspected, running a larger engine pulley will affect the steering bypass idler and the steering shaft. The double pulley clutch mechanism appears to to be WAY better designed and sturdy than I thought it would be.
The 17.5 engine. It's free and no water in the oil. I suspect a broken governor though. There was a suspicious spring added that would take up governor slack.
PostSubject: Re: Murray Hydro Widebody   Murray Hydro Widebody Icon_minitimeJanuary 2nd 2023, 7:43 pm
After comparing pictures.  The frame does not have previsions for the geared transaxle.  Also, it is in SUPER bad shape where the trans bolts up.
Murray Hydro Widebody Img_1227
There are provisions on Li'l Red for the double pulley clutch it appears.  I think right now, I'll continue to tear down for parts.
MN mudder likes this post
» Murray Hydro
» 4wd Murray widebody
» My Murray widebody
» Murray widebody lt
