 600 series??
nanner161988
nanner161988
600 series??  Empty
PostSubject: 600 series??    600 series??  Icon_minitimeAugust 3rd 2022, 5:59 pm
Can anyone give me imput on these transaxles? Is one better then the other? Going to be for a yard tractor but still would like to go 15 if possible and is there any videos of locking them if it's a good idea or not both vertical input pulley shaft and 3 speeds 600 series??  20220811
600 series??  20220810
Thank you ahead of time. Oppy 18.5 briggs powering it will plow snow have a sleeve hitch and 23x10 r 12 ditch witch tires. Hoping they are not to heavy
600 series??  Empty
PostSubject: Re: 600 series??    600 series??  Icon_minitimeAugust 3rd 2022, 11:24 pm
He's not around much, but @AllisKidD21 is pretty knowledgeable with them.
Tecumseh / Peerless Motion Drive System (wfmfiles.com)
600 series??  Sig115PROJECTS:
600 series??  Sig214600 series??  Sig314
nanner161988 likes this post
nanner161988
nanner161988
600 series??  Empty
PostSubject: Re: 600 series??    600 series??  Icon_minitimeAugust 4th 2022, 12:42 am
@mightyRaze thank you I actually have that book coming from ebay to have a better understanding of all the internals. Hoping @AllisKidD21 will be able to help me out. I have had good luck with one of my 930 seires thay I locked. Was curious on how people go about locking 801 seris with the bull ring ?? I think it's called. In my 930 I welded the pin to the gears. i just don't know how to go about it with the pin having to slide in to hold the spider gears in
600 series??  Empty
PostSubject: Re: 600 series??    600 series??  Icon_minitimeAugust 4th 2022, 10:39 am
I think a Fozzy lock would be the quickest, cheapest, easiest way to lock that style of diff and it's completely reversible if you're not happy with it (will impact your turning radius to some degree), find and weld a spare set of spider gears and swap em in/out as you please!
My All Terrain Tractors:
nanner161988
nanner161988
600 series??  Empty
PostSubject: Re: 600 series??    600 series??  Icon_minitimeAugust 4th 2022, 11:05 am
I came across some .750 shaft steel at work. So it can be a solid axle all the way through. But wondering if doc sprockets solid axle would work if I put the cross pin though and the welded it or if it would cause binding since there wouldn't be any play. Thoughts??
600 series??  Empty
PostSubject: Re: 600 series??    600 series??  Icon_minitimeAugust 4th 2022, 2:56 pm
Here is a thread here on ATLTF about locking a 600 series.
Peerless 600 "diff lock" (atltf.com)
HOW TO: Transaxle Locking Methods (atltf.com)
600 series??  Empty
600 series??
» peerless 600 series
» DIY Engine Porting vid series!
» Briggs And stratton 900 Series I/c ohv
» Briggs 300 series engine
» Mst 200 series ball bering support
