 -= Li'l Red =-
Dr Bob
MN mudder
TourMax
Budget_gokart
Nevadablue
darkside0914
Rustbucket Garage
redzz02
BlakeGroce
loggers gogert
Hillbilly Offroading
gimpyrobb
TheCollector
diddie
Rerun
29 posters
Go to page : Previous  1 ... 13 ... 23, 24, 25, 26, 27  Next
-= Li'l Red =- - Page 24 Empty
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 16th 2023, 9:56 pm
That Smart Car sure looks trail worthy to me!
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 16th 2023, 10:22 pm
Way to get r did @MightyRaze! I bet that Smart car would be blast to catch some air with!
My All Terrain Tractors:
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 16th 2023, 10:29 pm
It tickled me.
One last parting shot for the day.
-= Li'l Red =- - Page 24 Img_1333
What is needed from here:
  • Reinstall header pipes.
  • Wire up the flood lights.
  • Winch is connected.
  • Update headlights (rewire).
Remount hood
That will complete the front half of the tractor.
Then, I need to drop the transaxle in the rear, clean it and change the oil.  While I am at it, finish through bolts and change out the axle needle bearings.
-= Li'l Red =- - Page 24 Sig115PROJECTS:
-= Li'l Red =- - Page 24 Sig214-= Li'l Red =- - Page 24 Sig314
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 17th 2023, 10:38 am
OK, got a lot done this morning when I was taking a break from work.  I'm a little excited to show you my upgrade!
As for the front half of Li'l Red, only firing up the engine is left then it is off to the transaxle.
For now, I hope you enjoy these pix!
-= Li'l Red =- - Page 24 Img_1340
-= Li'l Red =- - Page 24 Img_1339
-= Li'l Red =- - Page 24 Img_1345
-= Li'l Red =- - Page 24 Img_1344
-= Li'l Red =- - Page 24 Img_1343
Much better than the fading, yellowing, and getting brittle headlights. I was also able to use the factory tabs with only minor modification to the lights!
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 17th 2023, 3:51 pm
SHE RUNS!  I threw some gas in it.  After turning it over a few times, she fired right off and idled.  Rev'd nice too. Almost a little spicy.  I did notice this engine had some kind of porting done, either professional or maybe a block update from the factory?  I know the ports had some modifications to make the air/fuel route more "direct" from the intake to the valve head.  We'll see how this pans out.
  1. The fuel pump works great.  Within a few seconds the filter was full.  A few more second VVvvrrooom!
  2. It runs!
  3. At first it ran a little "noisy" it had a lot of valvetrain noise.  At least at first. Guess the zddp oil treatment I used for reassembly ran off.  I didn't have any assembly lube.  After about a minute, noise subsided.
  4. Battery with the engine off was at 12.3V, with the engine running 1/4 throttle it was coming in at 13.4.  Alternator seems healthy.
-= Li'l Red =- - Page 24 Img_1310
It seems like a nice HEALTHY engine.  I hope it lasts.  Definately power the original lacked.
Time to pop off the rear tires and drop the transaxle!  I need some bronze inserts and some wheels for bowser.  I'd rather not go back to the wheel on axle.  I like having the ability to unbolt lug nuts.  Plus, they look better. (For Bowser's original tires, I'm taking back the bearclaws)
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 17th 2023, 9:49 pm
Well, I am done for a couple days.  Time for a break.
Trans is out.
-= Li'l Red =- - Page 24 Img_1347
-= Li'l Red =- - Page 24 Img_1346
And if you are interested.  Here it is taken apart.  Gears and everything look good. Oil looked good and no glitter.
-= Li'l Red =- - Page 24 Img_1348
-= Li'l Red =- - Page 24 Img_1349
Now to clean it out
Updates to the 820 planned.
  • Bronze sleeves
  • grease zerk for input?
  • Oil Drain? If I feel crazy.  The gear oil is pretty thick so I don't think it would drain "quickly" or completely.  So, probably not.  Especially since the oil was almost pristine.  I actually thought about dropping the gears back into the oil, but I dropped dirt into it.  Plus cleaning the old RTF will dirty it as well.
  • Through bolts.  I'm sure since I have had this open a couple times now, I will strip a bolt trying to torque it.
New updates this weekend.  Hopefully.
And I saw that silly lifted smart car again today.  LOL
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 17th 2023, 11:39 pm
Last update till the weekend.  I decided to take the hubs, lock collars, bearings inner and outer off.
Quick inspection, the Jb weld was discolored, and maybe a little dissolved? Uncertain of that.  Needle bearing on one side seemed ok but also seemed a little sloppy inside.  The other side was even more sloppy and gravelly.  It had done some wear on the axle.  Didn't look to have gotten hot so no discoloration.  Glad I am doing this mod.  I should have the bushings later this week.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 18th 2023, 8:59 pm
I know I said I was going to wait till this weekend, but I was notified my bushings are due in tomorrow instead of this weekend. So, I took it upon myself to clean up the transaxle, so it is ready for reinstall hopefully Friday.
-= Li'l Red =- - Page 24 Img_1350
I even knocked out the needle bearings in the sleeves. I'm 100% ready to install those sleeves, rtv, and add oil.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 19th 2023, 9:18 pm
OK, great success, but I am now delayed again.
So, since I didn't want to buy and cut up brass bushings.  I splurged and bought a set from Amazon.
uxcell Sleeve Bearings 1" Bore 1-1/4" OD 1" Length Cast Brass Self-Lubricating Bushing: Amazon.com: Industrial & Scientific
Well, what I got was an exact fit as the roller bearings.
-= Li'l Red =- - Page 24 Img_1351
Was able to knock them in with the same socket I knocked the old bearing out.  Axle is reinstalled in the case.
-= Li'l Red =- - Page 24 Img_1352
I could put it together right now, but I wanted to put through bolts on the 12 bolt holes that go all the way through to help strengthen the 2 halves.  I decided to order stainless for them.  :-)
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 19th 2023, 9:37 pm
Actually, I can put it together tomorrow, but just not install it in the tractor till Sunday.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 22nd 2023, 6:49 pm
such a good rig and looks like you have been working hard to make it even better
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 22nd 2023, 7:14 pm
Definately!  Want it to last the day, maybe a weekend when I can get it out to play.  Making things sturdier and stronger where possible.  My biggest upgrade left I would like to do, is a custom front axle.  I'd like to drop the front a good 4 inches after the lift from the monolink suspension.  Good to see members like @AllisKidD21 or @Brianator building one here on the site for easy reference.  I've lost one on FB like 5 times that I was watching.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 22nd 2023, 9:51 pm
Coming to the end of this update cycle.
  • Front bumper - New one made
  • Engine change - Engine changed to 17.5 Donor engine
  • Steering - No updates needed right now
  • Bronze update for transaxle - Updated
  • Grease zerk on input - Decided it would not be that beneficial
  • Refresh oil in transaxle - Oil refreshed
  • Through bolts in transaxle case - Stainless through bolts in transaxle
  • Replace front frame extension - New one built
  • gussets for lower shock mounts - Gussets welded on
  • update headlights - New LED headlights installed
  • Put Bear Claws back on - Bear Claws back on
Got these updates complete.  I decided against a couple of them.  Adding a tooth to the steering.  I think liquid filling the front tires would be more beneficial.  When I tore the transaxle apart, I noticed there was only about 1/16th or less than 1/8th of an inch area between the roller bearing and the needle bearing in the shaft.  The roller bearing was sealed, and the roller was getting ample oil penetration.  Decided against possibly messing either bearing or cracking the shaft.
So here are the last updates for now. (Lots of pix)
The stainless through bolts.
-= Li'l Red =- - Page 24 Img_1355
-= Li'l Red =- - Page 24 Img_1353
-= Li'l Red =- - Page 24 Img_1354
Now, let me reintroduce Li'l Red.
-= Li'l Red =- - Page 24 Img_1358
-= Li'l Red =- - Page 24 Img_1357
-= Li'l Red =- - Page 24 Img_1356
-= Li'l Red =- - Page 24 Img_1359
Felt the hood was a little "plain".
-= Li'l Red =- - Page 24 2240318088 -= Li'l Red =- - Page 24 2240318088 -= Li'l Red =- - Page 24 2240318088
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 23rd 2023, 12:10 pm
Looking awesome @MightyRaze way to revive it!
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeJanuary 30th 2023, 12:28 am
SO, I have been thinking a lot about the front axle on Red.  Instead of trying to reinvent the wheel, why not just change a part of it.
I've discussed building another new front axle for Red.  One that would change the orientation of the front spindle axle higher up so the nose of Red would go down.  Why not just build a new spindle on the existing axle?  Here is a quick drawing of what I had in my head.  I wanted to put it down on paper to see if it would even be possible.  Now that it is on paper, I think it would be even more possible.
The idea.
-= Li'l Red =- - Page 24 Img_1418
I'd probably build it using 1/4-inch plate. I'd also be using 3/4 bolts so I could reuse my front hubs. It'd be gusseted, cotter pin holes, and nuts.
Thoughts?
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 1st 2023, 8:59 pm
Hmm... the more I think of it... The reversed spindle sounds much weaker than having the C part on the axle. Even with some gussets.
I have that other front axle from the parts tractor. Maybe I'll look into it for more ideas.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 1st 2023, 11:08 pm
I think it would be plenty strong the way you sketched it, you came up with a really good design so stop second guessing yourself! Lol
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 2nd 2023, 12:24 am
This is kind of what I was thinking...
-= Li'l Red =- - Page 24 Drop-s10
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 4th 2023, 10:52 pm
OK, updates...
I did some measurements and decided to pull the trigger and start making the spindles.  Really helps that I have an extra axle that I can do my building with it on the table and not have to break down the tractor.
First the measurements.  I know after I redid the fix in the front to fix the massive bend, the front got noticeably nose up again.
Measurement of the frame at the back of the tractor was about 14.75 inches.
-= Li'l Red =- - Page 24 Img_1421
Subtracting the 1/8th for the extension angle iron the front is about 17.75 inches in height.
-= Li'l Red =- - Page 24 Img_1422
That is a 2-inch rise which doesn't sound like much but it's still quite a bit and pretty noticeable.
Got to bust out the big drill bits!!! Old drill they use to slip in the chuck.
-= Li'l Red =- - Page 24 Img_1423
Busted out the big sheet of 1/4 inch.  Drew out my "C"s and started drilling out my holes needed.  Needless to say, I measured twice then thrice, then a 4th time.  I was finally happy with my measurements before drilling.  The other lines are for scoring for bending with some heat.  I don't have a press for bending.  I'll bend and weld the gap.
-= Li'l Red =- - Page 24 Img_1424
All cut up and the first one is bent!
-= Li'l Red =- - Page 24 Img_1425
Here is that gap that I'll weld.  Has a nice V to it for welding.
-= Li'l Red =- - Page 24 Img_1426
Both bent and ready for test fitting.  Both came out pretty square. Funny how taking your time can make your fabrication more "exact".
-= Li'l Red =- - Page 24 Img_1427
And an initial test fit.  I just used the spindle since I do not have a bolt to run though it yet.  I also stuck in a piece of 3/4 pipe to check what a spindle axle would look like.
-= Li'l Red =- - Page 24 Img_1428
I'm liking what I see.  The 1/4 metal may actually be overkill.  Perfect!
I was curious how may inches this will lower the front.
The original spindle is about 5 inches from top of axle to top of spindle axle.  I know it says 6, but I was starting at 1 on this pic. Just being wierd I guess.
-= Li'l Red =- - Page 24 Img_1429
The new spindle axle will be located about 1 inch lower than the top of the axle.
-= Li'l Red =- - Page 24 Img_1430
This will be a nice 4 inch drop.  This gives me a couple options.  Keep the 2 inch rake in the front, or I can update the location for the shock attachment on the axle.  Right now, I am thinking about keeping the front rake.  I can flip the new spindle and gain another inch of rake if I wanted, but I am good with the new location that will be made!
Tomorrow I'll start planning up the tie rod links for the spindle and welding the bends of the spindle to shore them up.  I don't know if I need to gusset at this time.  I may do it anyway just for overkill. Better to do it now than later.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 4th 2023, 11:44 pm
I like it! Definitely gusset now while you’re there… those are the cut corners I’ve learned always come back and bite.
Personally I don’t like the look of a rake, but dropping it 4 inches gives you plenty of room to mess with tire sizes in the rear and maybe bring those down a notch and bring that center of gravity back down a bit. The center of gravity really effects the stability of a machine, which in turn, effects your confidence level on that machine lol.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 5th 2023, 1:43 am
Definitely do it now. No sense tearing it apart to add to it later. I was doing some looking and I may have to move my rack and pinion up higher. Not sure just yet. That's just 2 holes drilled, so no big deal there.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 5th 2023, 9:12 am
Looks like a great start! I wouldn't think 1/4" steel is overkill when it has to support the spindle itself.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 5th 2023, 8:08 pm
This has been a visual update. This is only a test.
-= Li'l Red =- - Page 24 Img_1431
This concludes the visual update. This has been a test.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 7th 2023, 12:00 am
Sillyness aside, I do have a video update on Red.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 8th 2023, 8:43 pm
Very slow progress.  I've been lazy.  lol
Bolt-axle is tacked in place.  It is straight now.  I was measuring for a small gusset for a washer to be flat against.
-= Li'l Red =- - Page 24 Img_1432
Small gusset tacked.  Showing the comparison between the new spindle and the old J-spindle.  Looks like the new one will be about 1/8 - 1/4-inch narrower wheel to wheel on each side.  I was initially concerned it was going to be wider.  Here you can kind of see the difference in ride height!
-= Li'l Red =- - Page 24 Img_1433
It's coming along.
PostSubject: Re: -= Li'l Red =-   -= Li'l Red =- - Page 24 Icon_minitimeFebruary 11th 2023, 9:15 pm
Excellent!  The front spindles are done!
I was measuring up for the tie rod.
-= Li'l Red =- - Page 24 Img_1436
Painted welded and ready for final install!
-= Li'l Red =- - Page 24 Img_1434
Hub and spacer installed!
-= Li'l Red =- - Page 24 Img_1435
Check that difference in Ride height!!!
-= Li'l Red =- - Page 24 Img_1437
Here is the before stance.
-= Li'l Red =- - Page 24 Img_1439
Here is the after!
-= Li'l Red =- - Page 24 Img_1438
The angle is a little wrong as it looks very nose down.  It is not.  This is just a dramatic angle for the drop. Front and back are now sitting 14.5 inches!  It's LEVEL!  Not sure how I lost 1/4 inch in the rear, but I'll take it.
OK, time for the tell-all on what needs to be fixed or didn't expect.
  1. I realized the J spindles were maxed for tie rod adjustments.  New spindles fixed that.  I have adjustment again.
  2. I didn't compensate for a little slack drupe in the front spindles.  This caused about 2-4 degrees of negative camber.  I think I like it.
  3. Only negative I have found at the moment, with the 19" tires on the front with the new geometry, I'm going to need to trim about 2 inches off each side of the front bumper.  I can flex it enough to get hung up.  Two inches and I think I am good to go!
Overall, I am super excited about this mod!
-= Li'l Red =-
Page 24 of 27Go to page : Previous  1 ... 13 ... 23, 24, 25, 26, 27  Next
