Ok thank you. Are they decent? Debating on locking it I possible thinking of putting it in my mtd 18 oppy that I been using as the work hourse around the yard. Maybe duel tires idk. Would be mainly for fire wood plowing snow etc. I guess my vision is a mini tractor / tow rig. And possibly attempt putting s peerless 700 in (eliminate reverse) as a 90 gear box to it for multiple lower gears. But if it turns out as a dud it would be fun to experiment and learn more in general for future projects
nanner161988 Member
Join date : 2022-04-21 Points : 1002 Posts : 38 Location : Northern WI
I guess any peerless is decent, having 2 in a row however would not be my choice. You don't really need 15 forward and 5 reverse gears. Even a JD 4066 has only 4 shiftable gears and 3 ranges.
I would just put a right angle gearbox in to avoid some potential drama
nanner161988 Member
I'm pretty much using what i got around. Budget builds mainly I know the 15 forward would be pretty ridiculous but don't plan on using them all. I haven't came across a right angle gear box yet
Id say do it 15 gears sounds like a really cool concept id definitely be following that topic. It might be a little overkill but then again why the hell not imagine how frickn fast that could go might wana be careful as the steering would be way sketchy going that fast. If you did want to go that fast you should use rack and pinion steering from a go kart.
Brianator, TechnoChicken and nanner161988 like this post
nanner161988 Member
Thank you very much. On my other build I uses old tie rid ends from a 90s chevy truck and that made the steering pretty strong. It tops out at 29 and don't have any doubts in steering at that speed so I will do the same but build an entire from axle and new spindles
i think with your setup you will be going a little faster than 29 the next thing would be the spindles add brass bussings or find a cast iron front end that can hold up to those speeds
fbisurveilancevan Member
Age : 38 Join date : 2022-05-20 Points : 1159 Posts : 220
Sorry for the double post here and I am kind a jacking this thread but I think you might be on a way to solve the greatest question of mowkind.
What if you would put a sprag sprocket and chain to connect both gears in the rear? That would eliminate the use for a belt and meanwhile you could simply use a single clutch and still be able to shift it without smashing the gears to bits right?
