 JD 400 as it sits now
FatMike
FatMike
JD 400 as it sits now Empty
PostSubject: JD 400 as it sits now   JD 400 as it sits now Icon_minitimeApril 3rd 2022, 8:44 pm
Got to drive this around a bit this weekend, it still needs lots of work.
Had to move it out of the garage to do an oil change on the van at the house up north and when I was done with the van I hopped on the JD and tested its fallen limb pushing abilities a bit, it did OK.
JD 400 as it sits now 27778210
JD 400 as it sits now 27779610
JD 400 as it sits now 27774411
JD 400 as it sits now 27779611
JD 400 as it sits now 27780410
MightyRaze, Brianator, Rustbucket Garage and Nevadablue like this post
PostSubject: Re: JD 400 as it sits now   JD 400 as it sits now Icon_minitimeApril 3rd 2022, 9:33 pm
Hey that looks pretty awesome! Triple spool hydraulics, steering brake setup and a 3 point on the rear... man you could get some good work done with that!
My All Terrain Tractors:
TechnoChicken
TechnoChicken
PostSubject: Re: JD 400 as it sits now   JD 400 as it sits now Icon_minitimeApril 4th 2022, 6:45 am
Hot dang, that's a pretty nice tractor, is the 3ph stock of did you add that in yourself?
FatMike
FatMike
PostSubject: Re: JD 400 as it sits now   JD 400 as it sits now Icon_minitimeApril 4th 2022, 7:03 am
Stock 3PH, I added the rear bar landscape rake system
I bought this a few years ago for $500 knowing the kohler was blown and all I have done is put in a predator 670cc, a tach, a volt meter/hour gauge it came with the blade and a mower deck.
The only safety switch it has is the neutral position so it will crank.
I still use the stock electric fuel pump to help prime the predator vacuum pump it is operated by the switch below the dash and is lit when on.
I still have a lot to do to it.
