This is my first mower build. it is a mid 80s Murray 18/42 with a 18hp Briggs opposed. I bought it back in 2021.
Mods. (so far) New front axle bushings with roller bearings 19x7-8 front tires (Ocelot p340) 25x11-12 rear tires (Carlisle at489) 6inch engine pulley (stock rear pully) kevlar drive belt
Mods needed. battery hold down new seat rear reviver hitch frame reinforcement new carb (china carb doesn't run right) front bumper gas pedal possibly split rear brakes or locked transaxle
N1ck Member
Age : 24 Join date : 2014-06-08 Points : 3905 Posts : 74 Location : North Central Arkansas
I'm starting the frame stiffing and I'm not sure how to proceed. My thoughts were to run 1x2 tubing inside each frame "flange". the problems i see are the brake linkage is on the way on one side and the clutch is in the way on the other side. i could run the tubing on the outside but that gets in the way of body panel and hood mounting. Anyone have any advise?
And you can see the odd belt routing
Brianator Moderator
I changed out the foot braced with 1/4 flat bar that is gusseted.
Sorry for the bad pic but I also made an exobrace across the top under the back portion.
These helped me quite a bit. not 100% but could help.
Thanks Raze. I like your ideas. I'm mostly trying to keep my hood from bending worse then it already is. And i like your suspension set up. That's a future plan.
