I think this might just turn into a pretty sweet rig, i'm watching her!!! What trails do you ride on? are they on you property or else where?
Thanks man! I'm hoping so too! I don't have trails on my property, I only have about 1/2 acre in a cottagey area (close to the lake) but just a couple minute drive down the road from me there's part of a HUGE trail system.
So the motor is freed from it's prison, man this thing is big and HEAVY! I'd like to actually weigh it but I'll guess it's close to a hundred pounds!
I'll tinker with it and clean stuff up while it's on the bench but the next main thing will be mocking it up in the tractor so I can build a motor mount for it, I'm not looking forward to slugging this thing around much! Lol
It's probably around 100 lbs. I weighed some various engines before and Briggs opposed twins are about 100 if I remember right. So that's probably close with that starter/generator.
It's hard to believe it could generate spark with so much corrosion on the magnet! The coil wasn't so bad though.
So I cleaned it all (plus all the contact points and wire connections)
A little something I like to do is put a thin layer of dielectric grease on everything, more of a film really so I have done that as well and expect the old beast to run even better than it did today!
Wow, that say 143? That's crazy. Can't beat old iron!
Especially when it's all old cast iron! The only aluminum on it is the cylinder head, carburetor, coil mount, magnet mount, front plate and booster fan! Lol. I don't even have to use a compression tester to know it's got plenty, it bounces hard off it when it's shut down so she seems to have tons of life left! It even already has the double belt pulley to match the tractor AND its the exact same size as stock but I will have to source a new slighter smaller double pulley to run the PTO and there just happens to be plenty of room on the shaft to do so! I've gotten very lucky, it's almost like it was destined to be!
Well I guess it's time to remove that little test motor and start mocking this thing up!
There is a single cylinder engine sitting in a lot in this subdivision. I guess I better ask about it. Could be a treasure. Fun to watch this develop. Buy a crane.
Brianator Moderator
Age : 45 Join date : 2019-07-02 Points : 4474 Posts : 2385 Location : Ontario, Canada
Thanks @MightyRaze and I wish @Nevadablue, even if I had one it would be completely useless to me here unless it was attached to a machine with wheels, I can only work on it outdoors as you can see in the first photo. What I've done is put a bench beside the tractor so I can more or less slide and quick lift it back and forth and then one big heave at the end of the day to get it back on the workbench. Yes it's heavy but it's also awkward! Lol.
I did make some decent progress today! I pulled the test motor out and plopped the big guy in to get an idea, looks pretty good in there!
No I won't be using that wood as the motor plate, that was just to get the test motor in there, I'm going to use the motor plate out of the Line Ward, it's 1/4" thick and the mounting holes are already there so that's a bonus
Even when it's sitting on it's proper mounting plate which is lower than that chunk of wood I'm sure I'll still need to work on the hood to make clearance for the the head/spark plug and will definitely need to relocate the fuel tank and do something about the exhaust.
This large angled support had to be cut off but I wanted to get a move on and figure out belt(s) length so I set it on a piece of 1/2" plywood (no picture), used some rope, came up with 32" and headed into town to grab some cheap belts (31" & 32") for $10 each, an idler pulley and some grade 8 hardware. I feel the cheap belts will be perfect for testing, polishing the pulley grooves and to keep as spares, I'll buy quality ones when the time comes. I cut the angled piece off after I got home.
I still need to trim the ends off but I wanted to do some more alignment and figuring, Houston we may have a problem... Here's my dilemma, the plate actually sits beautifully on the frame, and I can slide the pulley back for belt alignment plus it lets the motor sit as low as possible so that's all good but with the motor sitting in that location there won't be room for another set of pulleys on the engine to drive the PTO. Look at how nice the plate sits as is, let's call this this "option A"
"Option B" would be to slide the plate back, partially on top of the front clamps (which are 1/8" off height wise from one side to the other for some reason? so that adds another needed solution) and then have to add a spacer on the other end of the plate. This not only raises the center of gravity but also puts more weight forward and onto the front tires. I'm not liking "option B", seems sketchy and a pain in the arse!
"Option C" is to figure out exactly how much I need to move the front clamps forward and extend the (tube) frame that amount, that comes with yet another issue... the front PTO is attached to the front end! If I tried to space it backwards then the universal joint for the front attachments would either not reach or just barely reach... neither of which are good.
"Option D" is to "Keep It Simple Stupid!" Yknow, the KISS principle?! Lol. Go with "option A", keep options B and C in mind when altering the hood, relocating the fuel tank and reworking the exhaust. I know it sounds silly to care about the front PTO for a recovery rig/mudder but I've been secretly excited to be able to put the Snowcaster on it! My G10 runs it but struggles sometimes, it was never designed to run a 38" unit.
What would you do if you were me? Keep in mind I'm also working on stuff for The Warhorse in the background and plan on getting back into the actual build very soon, if I only had this one on the go no problem! Lol
Sorry for the novel guys! I still have a couple hours worth of motor work to post but I need a break, this post took forever! Lol.
It was beauty out today, around 16F and sunny! Last week was a little tougher hovering around -5F but I'm so used to it from working outdoors most of my life, the key is to dress for it! Wear many layers and stay hydrated! I do have a small electric heater to warm my hands and a propane heater for when I close myself in the workshed, don't worry it's not well sealed so there's plenty of ventilation! Lol
Once it started to get too dark outside to work I turned my attention on getting more engine work done in the workshed.
I figured I should get the pulley free so I can clean up the shaft and it will make it easier for pulley relocation/add another set behind it. To my surprise it didn't put up much of a fight, not even the hub!
Then again I did start sprinkling it yesterday with my favorite penetrating oil, if you haven't seen or heard of this stuff trust me when I say you want to find it! It's the best I've ever used and it's really hard for me to come by, my first can lasted me almost 10 years I used it so sparingly and only when I knew I needed it! I didn't use very much at all and you can see in the above photos how well it penetrated. It's an American company (I'm pretty sure) and they had sponsored a Nascar team at some point so you have a better chance than me at getting some... if you do please let me know I want another can! Lol. But seriously...
Once I had the pulley and belt guard off I cleaned the front plate and noticed all these hairline fractures... I hope they won't be a problem! I think it's best for me to start poking around and see if there's any new(ish) plates to be found! Hope you can see them in the pic
I decided to have a look inside the voltage regulator, almost wish I hadn't that's nasty! Once the motor is mounted in the tractor I'll test it out but by the looks of this, it's only fit to be a spare IF it does still work!
Then I started replacing shotty wire ends, cleaning up and (dielectric) greasing all the connections.
This was about the time I realized my beer was almost empty so I shut 'er down for the night! Lol. It's been an eventful one, hopefully tomorrow is as well!
I can’t work (by choice, if I don’t have to) in the cold these days. Glad you can handle it, this is fun to watch. You will need dual tires or those tracks on the front.
I'm glad too or I'd get nothing done for 4 months of the year! Lol. Feel bad for you, you must be going stir crazy!? Tracks you say... hmm.... nah not on this. That's an idea I've been tossing around for the derelict Cub Cadet, maybe next years build if I can find the parts over the summer!
No they're cheap as I learned today... look! I had to take a picture because I didn't believe it!
Now the idler pulley on the other hand....FOURTY freaking dollars for a 3" flat idler... not happy and shopping for another but I did grab it just in case I can't find another.
GOOD LORD! That’s ridiculous! I payed under $15 for one at TSC about a year ago.
ha ha ha... That's me everyy time I go to PP mart (Don't ask, it's what they renamed TSC) 4ft of fuel line is $30 bucks, I went to a local parts store the next time I needed some, IT WAS 3 BUCKS. Anyway, I feel you...
Your junkyard isn’t deep enough. I have flat pulleys in the pile. But postage would be more than the pulley probably. Plus the pulley would have to be vaccinated…
Brianator Moderator
Lol, I guess not but I already have 2 working ATVs plus 2 ATV frames, 5 tractors plus implements, a working walk behind snowblower plus a scrap one, 3 loose motors, 2 generators, the Line Ward, various bins of car parts ect ect... I don't need anything else I have a hard enough time keeping my yard looking decent with all this stuff! Lol. Oh ya postage from there to here isn't cheap these days or I would've ordered the proper pulley from Bolens Parts and Supplies, might still as he has a couple little parts I could use for my G10 but this pulley should work, it's a touch smaller than the original but is JUST the right width for the double belt system and I like the lips on the sides just not happy with the price, I hope it lasts a long time then it was worth it!
It's snowing like crazy but fairly warm today @30F, glad I have dry areas to work in!
I already knew I'd have to repair this hole in the frame but never noticed the hairline crack in it until today
A little trick I picked up along the way is to drill a hole ahead of the crack to prevent it from spreading any further so I center punched it, drilled a pilot hole then opened it up with a 3/16" drill bit.
I'll tackle it in the future before I paint the frame but for now I need to get the motor in and tractor moving, it's all still in the proof of concept stage!
