 Need to bend some metal but don't have a bender? No problem!
2 posters
Need to bend some metal but don't have a bender? No problem! Empty
PostSubject: Need to bend some metal but don't have a bender? No problem!   Need to bend some metal but don't have a bender? No problem! Icon_minitimeDecember 3rd 2021, 8:34 pm
First off, I'm a DIY kind of guy that believes in doing as much as I can myself, if I can fashion a way to get it done I will! I'm sure I'm not the first person to do it this way but I can't remember if/when I've seen it before. I'm building a winch mounting plate for The Warhorse and I had envisioned it being bent and then welded at certain points for strength but I don't have a bender and I'm not about to pay some shop an outrageous rate to do it for me plus... where's the fun in that! Lol. I do have a 5" metal bender for my bench vise but I don't think it would've cut it even if the jaws were tall enough to give it a try so I got to thinking and I figured if I cut a relief with the angle grinder (loaded with a thin cutting disc) that could maybe work! I've never tried this before, let's see what happens!
After cutting the reliefs I chucked it in the bench vise with a heavy piece of angle iron (to span the whole bend), gave it a go and it bent nicely right up until the 45 degree mark which is when the edges of the relief touched each other...
Need to bend some metal but don't have a bender? No problem! 20211214
Need to bend some metal but don't have a bender? No problem! 20211215
Need to bend some metal but don't have a bender? No problem! 20211213
So I grabbed the grinder and cut another relief along the bend but now that I saw the flaw in my plan I used a worn grinding disc to open up the relief cuts for the others bends.
Need to bend some metal but don't have a bender? No problem! 20211217
Need to bend some metal but don't have a bender? No problem! 20211216
I tossed it back in the vise and viola! 90 percent of the way there! A little persuasion with the BFH and it was now sitting at 90 degrees! (not pictured) Need to bend some metal but don't have a bender? No problem! 20211218
Need to bend some metal but don't have a bender? No problem! 20211220
Need to bend some metal but don't have a bender? No problem! 20211219
That's all folks, class dismissed! Get out there and bend some metal!
My All Terrain Tractors:
Nevadablue and CharlieMac67 like this post
Nevadablue
Nevadablue
PostSubject: Re: Need to bend some metal but don't have a bender? No problem!   Need to bend some metal but don't have a bender? No problem! Icon_minitimeDecember 3rd 2021, 10:51 pm
Good idea! I have to make a mount for my winch and will probably cut the bracket and weld it. But, your idea may work for this. Thanks!
PostSubject: Re: Need to bend some metal but don't have a bender? No problem!   Need to bend some metal but don't have a bender? No problem! Icon_minitimeDecember 3rd 2021, 10:59 pm
Thanks! Still requires welding but not nearly as much (just on the inside of the bends) AND it gives nice rounded corners! I'm giving myself a pat on the back for this one! Lol
Nevadablue
Nevadablue
PostSubject: Re: Need to bend some metal but don't have a bender? No problem!   Need to bend some metal but don't have a bender? No problem! Icon_minitimeDecember 3rd 2021, 11:10 pm
Yep, good way to make the bends straight too.
My bracket is already a right angle and I need it straight. I’ll try cutting half way through with the cut off disk then bending.
» Do I have a govenor problem or a throttle problem?
» CONSENT
» i dont want to blow it up...
» shifters that dont rub the belt?
» most people dont think to do brake lights like this...
