Lol. I hope so but I'm concerned about where those fragments are coming from...
Not sure about the ridge I ran my finger across it and didn't really feel anything so it's probably fine, the bore itself looks square and there's no play (rocking) in the piston surpringly.
Well boys, she's torn down, inspected and will be worked over while I'm waiting for the gasket kit to come in.
I was able to fish a bunch more metal out of the oil in the crankcase (this is just a small sample)
The gears are perfect with almost no visible wear, also no chips or scores...
The piston rings are in great condition and have plenty of tension on them so they'll get reused. There's a bunch of gunk including metallic grit all throughout them but the piston is still really decent as is the connecting rod and crankshaft main journal
With the good news out of the way it's time to get to the bad news.... for the life of me I cannot find any contact points or an explanation of where all the metal came from! The Synchro plates, the bearings, the gears, the valves, the governor just everything looks really great, even more so for a 37 year old motor and everything still feels tight so I'm stumped! Lol. I should be celebrating but now I'm more concerned then when I started because I couldn't find any witness or contact marks yet there's a good amount of chunks of metal.... maybe bits of flashing that's broke off from the edges of castings? *sigh*.
I'll be looking even harder as I clean/polish everything and reassemble, I hope something shows itself or I'll lose it! Lol
Interesting. I’m curious to see what your verdict is. I don’t know what it is about these flat head briggs, but out of all the small engines out there these seem to have the most interesting and bizarre issues when they happen. I saw this one english guy rebuild one where the connecting rod had absolutely destroyed the valves when it snapped. Wrist pin had jammed into the liner when the c clip broke, now I wonder if maybe that could be a factor? Tough engines and they’ll last for forever though.
Brianator Moderator
I used a magnet, even the chunks I first picked out of the cylinder I checked with the magnet and most of them were magnetic.
Just for the record I've been inside and worked on plenty of engines, it's not the first time I've come across metal but it's usually in flake form which is fairly normal wear and tear. I've only seen (small) chunks in gearboxes, can find evidence of where it's come from and not been overly concerned but this is just bizarre! I'm really suspecting it's flashing from edges of the castings but I'm not coming to any conclusions yet.
Well guys I don't really have much in the way of an update but I can say I've been slowly cleaning/polishing engine parts getting them ready for reassembly and I still for the life of me can't get to the bottom of where the chunks of metal have come from! I'm just going to let it go and move on, it's obvious to me that it's not been caused by any interference so now that it's cleaned out it will no longer be a concern!
I'll probably start a thread in the engine section for it and set up a link here, theres lots of work to do to it before I start reassembly, I'm working on the carb right now and giving it some personal touches so the airflow is improved and as smooth as possible without killing velocity.
That's super thank you! May I copy my build progress here also for completeness of my build thread I've worked so hard on!? Lol. I do understand I need an official Build Off thread.
On another note, I've started a seperate thread in the engine section for the motor from this old girl. It can be found HERE for all who are interested.
There will be an official build-off thread. Historically, we lock this thread while the build-off is running. Then if it continues afterwards, I think if I remember right, I can link them together and unlock.
Well guys I don't have anything in the ways of a progress update as the last time I worked on the tractor itself was Dec 31st when I cleaned up and painted the front of the chassis in preparation of reassembly, it was a little chilly out that day so I used a small electric heater and made an enclosure out of work mats so it would dry. I forgot to post these that day but better late than never right?!
The ol' girl is still sitting there in the exact same spot, in the exact same state, for 3 reasons... 1) I've been working on the motor and want to have it assembled so I can get a pic of it with the tractor for.. 2) The Build Off which... 3) I'm still contemplating whether I'm going to enter it into or not... I've been leaning towards it and thought it would be best to leave it in it's current state for the entry photos just in case.
I also (selfishly) wanted to bump the thread so those following don't think I've abandoned it and new/old members coming out of hiding see it pop up on their radar and hopefully check out what I've been up to! Lol.
I hope everyone has had a strong start to 2022 and that it ends the same way for you! Until next time fellas!
Oh she'll be "complete" to build off requirements (not like they're ever "complete") WAY before then! I plan on doing alot of serious test&tune and break, repair, repeat this summer! I'll probably be breaking, tweaking and tuning stuff before the snow is even gone here! Lol.
Well I got the beast back on it's wheels today, it was in the way of being able to work on the 16hp B&S I've mentioned in another thread and I've been stalling making it mobile for far too long now!
I greased up and installed the steering gear and greased the front of the chassis
Greased up the inside of the front plate and installed the axle. I didn't realize how much articulation it had until now, it was seized solid before I took it apart! Lol. Only time will tell if it's enough...
Then I popped the wheels back on and I set it down. Nice to see it on it's feet again and wow the steering is smooth as butter now I'm loving it!
Now that it's mobile again I'll actually be able to work on it again! That's all for now, hopefully I'll get more done on it next week.
You're right there's not and you're right I did! Lol. It still turns pretty sharp before the rim contacts the axle but it's all good because I have a secret weapon that will take care of it and giver a nice upgrade! I love the tires too, it's a set of 4 that came off a offshore atv, wish the rear were a little bigger but then the machine would go back to being lower in the front!
The next hurdle will be the motor "isolators" as mine were crumbling upon disassembly! They're made out of stiff rubber or polyurethane or something similar and they're ridiculously expensive to replace for what they are! I don't even remember the exact number(s) as I was so flabbergasted I instantly deleted the info my memory bank! Lol. I'm pretty sure I was looking around $50-60 for 8 of them and there's no way I'm paying that for them! I also don't want to go solid mount or just use flat, thick rubber because they're also the locators for the mounting plate and prevent it from shifting around. For several weeks I've been looking for 1/4" polyurethane or even Teflon (it's strong and has a little give to it) to make new ones myself and have come up empty handed... the only thing I've found is a fiberglass materiel/resin that's heated and pressed into a super duper strong material that's commonly used to make knife handles! They call it "G10" and it was cheap, like $10 for a small sheet of it.
The plan is to make 4 that will go into the chassis from underneath and be flush with the top of it then use the 3 and half remaining decent original ones in the motor plate, from underneath and I will retain the vibration isolation properties of the original parts while reducing the overall amount of flex/twist of the motor!
Here's a picture of what's left of them stinkin' isolators and the hardware.
I look forward to getting back to work on this old girl soon but getting The Mud Duck moving under it's own power has taken priority for the time being!
Don’t forget plastic cutting boards for making parts. They come in a lot of different thicknesses and are cheap and strong.
Hey ya great idea! Why didn't I think of that!? Lol. Some are a Teflon like material or actually Teflon, next time I'm out and about I'll have to have a look thanks for the tip!
I’m going to make the steering wheel ‘bearing’ for the rat rod out of a 1” thick chunk of cutting board type plastic. I think it is polyethylene, not sure.
