 my engine keeps overheating
Fastman
Fastman
my engine keeps overheating Empty
PostSubject: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 11:49 am
so my '91 wizard has a old briggs flat head (took me 3 years to find the engine) and it keeps on overheating the engine runs amazing but it keeps overheating does any body have any clue what i can do to fix this?
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 12:21 pm
Well how do you know it's overheating?
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 1:22 pm
What DWCR Said.  Also, maybe post up a pic?  Does it have all the tins?  Flywheel blades all there?  Mouse nest under the shroud?  Too hot spark plug?  Carb too lean? Low on oil?  Gas in the oil?
my engine keeps overheating Sig115PROJECTS:
my engine keeps overheating Sig214my engine keeps overheating Sig314
Fastman
Fastman
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 1:53 pm
so i start it up right it drives real good or about 1 hour (that is a estimation) then it dies and when if i try to start it up as soon as it dies it takes about 2 mins of cranking before starts but only runs for about 15 mins and then dies but if i let it cool down for about a hour or to after it dies the first time then it just starts right up
Fastman
Fastman
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 1:57 pm
it has all the tins but i took the one in front of the head off because i got tired of having to take it off every time i cleaned the cilinder walls
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 2:05 pm
Clean the cylinder walls?
Could be you coil going out, plugged fuel filter, collapsing fuel line or even a gas tank vent obstruction.  They all can cause the described.
Fastman
Fastman
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 3:31 pm
well i dont think it has anything to do with a fuel filter (i redneck the whole tractor) i couldnt afford one when i did all the plumbing
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 5:12 pm
Like @mightyraze said with the coil, when it shuts off check for spark. Mouse nests are very common on these so I’d pull the tins and check. If you do have one and that’s what is causing this I’d replace the head gaskets too. The heat makes the head bolts stretch and contract and it might hurt compression that way. Which is the other thing that might cause the shut off, is a lack of compression from the heat expansion. Just my 2c
Fastman
Fastman
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 5:17 pm
well i had all the tins off the engine just 2 days ago so i dont think it has any rats nests because it didnt 2 days ago
Fastman
Fastman
PostSubject: Re: my engine keeps overheating   my engine keeps overheating Icon_minitimeJune 18th 2021, 5:21 pm
im thinking about just puting the engine i have on my gocart aka The Frankin Cart on it and swaping the engines (the engine on my gocart is turned way up so it will prolly be doing wheelys if i swap em so that will be fun)
» 14.5 overheating
» 14.5hp overheating and bogging
» Honda HT-R 3009 mid engine rider engine swap
» Craftsman off road tractor
