 Turning at fast speeds equals no turn
murphyslaw
murphyslaw
Turning at fast speeds equals no turn Empty
PostSubject: Turning at fast speeds equals no turn   Turning at fast speeds equals no turn Icon_minitimeDecember 31st 2020, 11:09 am
I noticed with my Sears Craftsman II that when I try to make a turn going full speed that it will continue to go straight as the front tires drag on an angle, after about a good 15 ft it will finally make the turn. If I slow down a little bit it stops dragging and makes it turn instantly. This is a stock tractor with no modifications on it. How do I prevent it from doing this. More weight on the front end? Maybe bigger tires? Heavier tread instead of turf tires?
I want to be able to get this fixed before doing any modifications. If I'm going to make it go any faster I don't want to not be able to turn at all when cruising around.
darkside0914
darkside0914
2020 Build-Off Top 3 Winner
PostSubject: Re: Turning at fast speeds equals no turn   Turning at fast speeds equals no turn Icon_minitimeDecember 31st 2020, 3:16 pm
i would say a grippier tire would improve it a lot, turfs are more or less meant to slide along the grass to prevent ripping it up when mowing at a lower speed, so a more aggressive tread pattern should help out greatly,
PostSubject: Re: Turning at fast speeds equals no turn   Turning at fast speeds equals no turn Icon_minitimeDecember 31st 2020, 3:37 pm
About how fast is full speed?
murphyslaw
murphyslaw
PostSubject: Re: Turning at fast speeds equals no turn   Turning at fast speeds equals no turn Icon_minitimeDecember 31st 2020, 3:40 pm
Thanks darkside!
Where are you guys find new tires at? I heard somebody say they take the back tires and put them on the front.
Full speed.. idk how fast it is.. maybe 8 miles per hour but that's a complete guess
» Need ideas on how to get higher speeds out of a FNR transaxle
» 3spd Gearbox pulley & chain what speeds are these good till?
» Tecumseh hh100 carb
» Look what happens when you turn 67
» Tracked zero turn
