 Larger Tractor 9N
11 posters
Larger Tractor 9N - Page 3 Empty
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 26th 2020, 6:21 am
Nice job Mighty! That ol' flathead sounds great!
loggers gogert
loggers gogert
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 26th 2020, 8:53 am
about how fast does it go in top gear?
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 26th 2020, 10:55 pm
Thanks, still some throttle linkage issues that need tweaked, but she's running!
If I had to take a guess, around 10mph.
Larger Tractor 9N - Page 3 Sig115PROJECTS:
Larger Tractor 9N - Page 3 Sig214Larger Tractor 9N - Page 3 Sig314
loggers gogert
loggers gogert
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 27th 2020, 10:10 am
10mph? holy cow, i bet that thing has a TON of torque
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 31st 2020, 10:29 am
Current Update:
Been fiddling with the 9n. It just isn't right in the Carb. I barely touch the highspeed jet and it wants to die, low speed appears to work fine. I know the gasket is torn inside so I know gas is leaking probably to the wrong areas. I know it is missing the manifold gasket. The other day I was watching a rebuild video and quickly realized. The carb is MISSING SOME INTERNAL PARTS! Yikes! And it runs that good without?
I toyed with the idea of a $30 Chinacarb, or a rebuild kit. I decided to do the right thing and rebuild it since the carb appears to be in good shape. Not sure when it will get here. Got me a new sediment bowl as the one I have is somewhat ok, but the rubber plunger is shot. I may rebuild that for later.
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMarch 31st 2020, 11:48 am
@MightyRaze yeah rebuild kit is way better then a cheap online carb. I rebuilt my carb of my great grandfathers 1963 International Harvester 404 Utility Tractor. After fixing the I still have a list of stuff to fix. Hasn't ran in 3.5 years.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 18th 2020, 9:19 pm
Got my carb kit finally today in the mail.  I was smart and tore into it by halfs.  In the top half it was missing the idle jet and an economizer jet.  Choke rod was busted and missing a screw.  Choke spring was ran wrong.  Both the throttle and choke shafts were missing packing gaskets.  Main jet needle was missing a washer and gasket.
Larger Tractor 9N - Page 3 Img_2330
Runs MUCH better now.  I still have not completely dialed it in yet.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 18th 2020, 9:52 pm
Good to hear you've got it going better.
Does the cylinder powering the arms run on trans oil? I think thats how the Deeres in the same era did it. Early hydraulics on tractors was really a lawless hellscape, lol.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 19th 2020, 12:28 am
The trans and the pump for the arms run on the same hydraulic oil.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 19th 2020, 4:05 pm
Crazy to think it ran at all with the carb missing a bunch of stuff. I'm interested to see what kind of difference this makes.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 19th 2020, 9:42 pm
It didn’t run too well but it ran with those parts missing. I should have video’d today; I was running it today pretty good.  Noticed the governor screw is missing. I got a couple implements for it from my father in law. I was using the blade to push my tree pile together.
3 pt boom
Larger Tractor 9N - Page 3 0259f910
And a blade...
Larger Tractor 9N - Page 3 150bad10
And a parting shot
Larger Tractor 9N - Page 3 B38e3a10
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 20th 2020, 8:42 pm
Here it is running!
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 21st 2020, 11:01 am
Sounds like a very smooth purr. I didn't hear anything out of the ordinary.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeApril 21st 2020, 1:48 pm
It was missing a governor bolt so it would start to race at times.  I could not figure out or find a bolt that would fit the threads on the governor.  I tapped it to a common bolt size this morning and installed a bolt.  Now to figure out where to initially set it.  Need to look at a manual for that.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMay 23rd 2020, 10:45 pm
Minor upgrade for the Ford...
Larger Tractor 9N - Page 3 Img_0012
Larger Tractor 9N - Page 3 Img_0011
Larger Tractor 9N - Page 3 Img_0010
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeNovember 10th 2020, 10:19 pm
The old 9N gave out this weekend pushing limbs. I shut it down and it would not restart.  Fuel delivery is good, but spark is not quite right.  I checked the points, and they were fine, but something is not right with the distributor. If I mess with the cap, I can alter the spark.  That and it appeared to have been running on 2 cylinders when I shut it down.  Plug wires 3 and 4 seem shot and corroded.
I'll get me a tune up kit that contains plugs wires and a new distributor cap.  See how that goes.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeNovember 12th 2020, 5:18 pm
Sounds like the cap or wires. Wouldn't surprise me on a tractor of that age.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeNovember 12th 2020, 10:41 pm
I know plug 3 was bad corroded and not touching the terminal.  I should have the tune up kit tomorrow.  4 plugs, wires, points condenser and cap with rotobug.  I'll try to install Sunday if it does.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeDecember 26th 2020, 8:15 pm
For the lack of not being able to do much, I am hoping to record a 9N update tomorrow. It has been down and not running for just over a month. Especially right now while I needed it most. My back has been horrible for the past month. Hoping to get something accomplished next week or have a plan to fix on that.
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeDecember 27th 2020, 6:43 pm
Kind of a end of year update!
PostSubject: Re: Larger Tractor 9N   Larger Tractor 9N - Page 3 Icon_minitimeMay 7th 2023, 11:58 pm
Got the 9N out today and cleaned up the driveway and the spot for the camper.
Larger Tractor 9N - Page 3 Img_2469
Larger Tractor 9N
» Clutch gets in way of a larger pulley
» Securing Larger Front Tires
» Need input on 4 on 4 hub conversion, wheels, and larger front tires
» MTD= Mudding Tractor Domination (aka my tractor)
