| '98 Honda Recon 250 Lifted 4wheeler | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2853 Posts : 582 Location : Reeses Mill, WV
diddie Member
Age : 57 Join date : 2016-10-02 Points : 3430 Posts : 411 Location : Indiana
| Subject: Re: '98 Honda Recon 250 Lifted 4wheeler January 17th 2020, 10:50 pm | |
| i like those big fat tires ! and the paint is just battle scars that it has earned. pretty paint is temporary for a work horse ! | |
diddie Member
| Subject: Re: '98 Honda Recon 250 Lifted 4wheeler January 18th 2020, 10:45 pm | |
| @diddie no power loss? Interesting. Thats great news then. I figured with the smaller hp engines you would be able to notice a difference and when you got up to 24hp engines 1.5hp wouldn't make that big of a difference. | |
| Subject: Re: '98 Honda Recon 250 Lifted 4wheeler April 27th 2020, 9:06 am | |
| Theres some new things that have been done to it. I have gotten rid of the stock 11" narrow front rim and have I starred one of the tires on a honda rancher 420 rear 11" rim to get some more width out of those 25x8x11 and theres a huge difference. Off set is great it is the same width are the rear end. No more spacers on the front and either way it still out farther then with the spacers so looks like a 4x4 now. Not though. Only a inner tube would work. Just have to bust the bead on the other and paint it. Cant decided to go green or this brown but I'm just using it as a primer to spray the green on it I do green. They was extremely rusty. Now the new thing. It's a rear hook up tractor plow. I want to fabricate some mounts and use it on my quad. | |
| Subject: Re: '98 Honda Recon 250 Lifted 4wheeler February 16th 2021, 5:22 am | |
| My sister asked for a igloo so she got it. Pushed up a half of a acre in to a pile. Had to leave alot so I didn't trash the field. Snow had turned to ice. Some spots was 8" and others was all the way up 12" range. Its a 16'x12'x5'4". It was a little to much for the bike. 6 hours of non stop plowing. Fighting up hill it most spots wasn't good. Went through 2 ratchet straps and bent the plow pins pretty bad. Rear rack is about to snap off. The foot boards are completely busted up and shot from getting on and of all day doing the ratchet strap. The bike isn't doing good. I've lost all rear brakes and shes smoking pretty good now. As soon a you give it a little throttle its blue. Really sucks. Cleaning up the wood shop now to pull it in for some must needed repairs. Here's the list. - Change the rear end oil. Must be water in there freezing up from creek riding last spring. - Oil change for engine. -Install new bolts in the rear rack. Sheared 2 of them from that 150lb Luggage tote moving around. - See if the foot boards can be stitched back together. I busted them up. - Tape up seat. Shes all ripped to shreads again. - Figure out why the the light bar won't work. Toggle Switch probably went bad. - Winch plate should be coming in soon to install that. - Id like to slide the light bar back to be able to add weight to the front of the bike. - New Foot brake cable - Adjust carb. Running a little too rich in high throttle - Want to jet carb later this year. - Add a after market cdi box to go with the jetting to be able to go beyond the stock rev limiter. - Don't have materials to make a proper plow mount for the bottom of the bike so gotta order one. - Weld on a new edge to the plow. - Add those gravel skids to the plow. This plow was obviously built before they was a thing on quad blades. Lol! | |
