 2001 F150 build
5 posters
Go to page : Previous  1, 2
2001 F150 build - Page 2 Empty
PostSubject: Re: 2001 F150 build   2001 F150 build - Page 2 Icon_minitimeNovember 26th 2019, 6:06 pm
have you checked fuel pressure while drivin? I had a truck that would test fine idleing/revving sitting still but lost pressure going down the road.
PostSubject: Re: 2001 F150 build   2001 F150 build - Page 2 Icon_minitimeNovember 27th 2019, 8:33 pm
I been working on my kids 5.4l expedition, got some knowledge lately, LOL. The knock in the motor, when the coil packs stop working for some reason the lifters collapse and knocks on that dead cylinder while driving or reving in park but sounds ok idling. Can loosen the manifolds to see it that helps, to check if cats are plugged but don't think so. I would focus on the coil packs and spark plugs for the loss of power, pretty common problem with these engines, along with vacuum leaks. Ford used crappy vacuum lines and they go bad easily. If you got a scanner that can read live data, that helped out a lot with me on the Expedition of my kids. ScannerDanner is pretty good on YouTube and does a lot of these trucks, LOL.
PostSubject: Re: 2001 F150 build   2001 F150 build - Page 2 Icon_minitimeNovember 27th 2019, 8:45 pm
Has new plugs. Ideally I’d do a power balance test and figure out exactly what cylinder it is. Because it DEFINITELY has a miss
2001 F150 build
» F150 off-roading
» CC's 1993 F150
» 1980 ford f150 4x4
» 1978 Ford f150 Ranger
» Pony's 1977 Ford F150 4x4
