| [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] | |
+9Crazy_Carl Murraymountain SebastianAlbrecht diddie Double W Cross Ranch prancstaman AllisKidD21 MightyRaze TheCollector 13 posters |
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] October 22nd 2019, 9:51 am | |
| Always a good feeling to finally get to use something you have been building for a while! She's a beauty. I know you are finishing up. Just let us know when you are complete and have your walk around video!
Great Job. | |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4434 Posts : 2178 Location : North Carolina
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3738 Posts : 194 Location : Bedias. Tx
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] October 22nd 2019, 7:44 pm | |
| Thanks. I might add something else to the build but not sure. I need to see how it will look on mock up if not a finish video will he coming up. @murraymountain im just very excited to finish this time around its been something I have wanted to do for about 4 or 5 years now and something always comes up. | |
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] October 23rd 2019, 10:46 pm | |
| Back out in the shop today to add a little more to this build. Made a cover to cover up the cut out in the frame that i guess the original cover slide into. Made a drink holder and can also set you phone next to it without it sliding off. I covered the top in grip tape. This is the original exhaust shield to the motor. Took about 2 hours to get the circle cut. looks almost factory to me Fourth pic down got my boy out there helping me. Lol hes probably touched just as many nuts and bolts on this thing as me Took the dremal and cut these notches bet the over and ground them out Covered the top in grip tape Happy with the way this came out | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4061 Posts : 870 Location : Phillydelphia
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] October 26th 2019, 11:00 pm | |
| Today was a good day. I rode the Murray for about 1hr only two things came up. One the throttle cable came lose where it clamps down by the engine only need to tighten the bolt back down so no biggie the other thing is I was getting belt slip in higher gears. Come to find out that the shift lever was bulling the belt away from the pulley so also got that fixed up. She is getting more and more refined each ride. I have one more thing to do and its in the mail then i will wrap this build off up. Also have been taking video so will have some sort of that coming out. Never really put a video together so we will see. Here are pics of the shifter fix and also a pic of it all washed up after a good ride All clean | |
TheCollector Member
TheCollector Member
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] November 2nd 2019, 11:40 am | |
| Loving the rock slider! Looks pretty slick with the angle cuts in the end, should work great too! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] November 2nd 2019, 11:13 pm | |
| Thanks its more of a guard but is strong enough for a step. Chipped away at this thing a little more today. And decided to redo the clutch I got tired of the stock modified clutch not working the way I wanted so built a new double clutch and got the retainers on there as well. Also lengthend the shift lever and welded on some threads for a shift knob. Its crazy how much time these small things eat up. New shift lever and knob. Looks and will feel so much better | |
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] November 5th 2019, 10:34 pm | |
| Was a huge pain but both sliders are done. Im done with the apperance of it now. I Also installed a light under it for maintenance or if I throw a belt. I will be addressing wiring in the next few days then im done. So i hope to have this wrapped up next week sometime | |
TheCollector Member
TheCollector Member
| Subject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry] November 8th 2019, 8:32 pm | |
| Ok this tractor is done!! I hope to get final pics and video tomorrow if weather is good but the building is over. Ok well i did the challange of wiring the last few days. The firewall plating is from a ammo can. I wired the all accessories Into a fuse block the wires are ran though the plating with rubber tube to protect the wires Before During what a huge mess Wiring is done
Last edited by TheCollector on November 8th 2019, 9:10 pm; edited 1 time in total | |
TheCollector Member
