 [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]
diddie
TheCollector
13 posters
TheCollector
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Empty
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJune 23rd 2019, 10:54 pm
Thanks guys!
@sebastianAlbrecht I hear ya it always takes me forever to finish a project as well. Im giving it my all to finish this year. This Texas heat is not helping
@ murraymountain i will for sure clean up those cuts And if i can afford tires by the end of the build i might throw some ag tires on not exact tread but closer to what factory would be i think.
@ mightyraze its the best i could come up with without welding on the hood. Had to keep the stock lenses. Lol
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 10th 2019, 10:09 pm
Not much of a update its been hot in Texas but i wanted to keep within the posting rules..i did get some wiring done, i cut into the stock harness and cut out all the safety switches and cleaned things up a bit. This is the 1st time I have turned the engine over so starter is good as Well as spark in both cylinders! Next will be exhaust and throttle and i hope to hear it run.
Was already a little i to the clean up but did get a pic
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190626-175410
Here is where im at now. There will be more wiring to come with the lighting and such.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190626-195138
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 11th 2019, 11:00 am
This build is awesome, I think this might be a winner too!
I like those stock wiring harnesses. They're not too hard to clean up, and you can still use a key.
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 13th 2019, 12:05 am
Thanks murraymountain! Well i had a break in the heat today and decided to get some work done. Im all over the place on what im doing next but today was rounding up some brake parts and making something happen. Got brake part from a junk ATV.
To adapt the disc hub to work with the trans axle I cut the hub out of a rear mower wheel and turned it down to fit inside the disc hub so the key way will hold it in place on the axle.i have about 1/4 inch clearence issue getting the wheel to fit but I can take that from the front of the wheel or maybe space the disc out some. Not to big of a deal.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190712-193306
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190712-194027
Adapter inside disc hub just need to weld up
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190712-193346
And where I had to end for the night
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190712-201421
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 14th 2019, 5:46 pm
And a hydraulic rear brake too? I'm really liking the progress on this one!
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 23rd 2019, 7:44 pm
Finished up the brake mount other than notching for keyway. Other than that did some work on mounting the air filter. I wanted the engine to breath good so went with a 99 kx125 filter this filter is temp as I pulled it off my bike to figure out the install but i will be going with a nice new red one to match the build.
Not the best welding but im newish to stick welding
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190715-194110
Finished up mounted and hub welded next notch for keyway
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190715-203808
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190723-162108
☝ up top these parts for the filter are made from a cutting board
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190723-174722
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190723-174815
And this will be the filter i use
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 S-l400-1
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 29th 2019, 5:58 pm
Got the ebrake lever in the mail. What a deal that was wanted it red guy on ebay gave a tracking number few days go by and it never shipped so after dealing with ebay I got a refund and found one in black that was actually located in the U.S. after having it very happy its in black. Now im waiting on banjo bolts so i can convert it to work with my atv caliper.. Waiting for parts is always fun. 😆
Also i have been working on the exhaust had trouble with the welding of the thin tube with a stick welder but progress is being made hope to have this part finished in the next few days
This will be where i mount the ebrake
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190729-164202
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190729-164324
Headers made from a old dog pen still lots of grinding to do where other post where welded to it also got some nasty welds to clean up
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190729-164221
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 29th 2019, 10:23 pm
Looking at this thing i could make a foot brake. Take off the handle and drill and tap and pedal on It. Something to sleep on but i like the idea of ripping the ebrake.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190729-210820-1
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 30th 2019, 7:43 pm
Finished up the exhaust today
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190730-170129-1
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190730-181641
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 30th 2019, 10:58 pm
Went out a little while ago and got the banjo bolt and a bag of nuts and bolts from tractor supply to replace the hardware all around the tractor.
The Banjo bolt size for this is 3/8-24 all they had was a long one so will come up with some spacers tomorrow. This leaves me with just the brake fluid tank and the brakes are complete.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190730-214800
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 30th 2019, 11:10 pm
That exhaust header turned out great! Super slick looking!
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 31st 2019, 10:25 am
Looks great! I assume you'll be tying that gas line up higher somewhere? Little close to that header lol!
Destructive
Destructive
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 31st 2019, 11:29 am
Love the Hydro brake setup! Cant wait to see a video of it in action!
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 12th 2019, 9:48 pm
Fuel line will be ran out of the way of the header waiting for new fuel pump and cut off to finish the fuel system. Both are on the way.
Well have not done much it's been 109 outside so hiding inside from that. Lol
I got new tires for the rear in today went with the 18x 9.50-8 ag tires same size as whats on it now. Im trying to keep the c.g down with how it will be used.
I have various other parts coming in the mail this week and hope to start it next week.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190812-203411
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 13th 2019, 8:37 pm
Got the tires mounted on wheels and on the Murray.
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190813-192249
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190813-192304
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 13th 2019, 9:55 pm
Looking nice... Do you sand or sandblast your parts?
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Sig115PROJECTS:
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Sig214[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Sig314
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 13th 2019, 10:10 pm
Thanks! Wire wheel and flap disc is what i have used so far. On my second harbor freight grinder just from this project alone.
Looking at the back of this thing today i have decided im going to be removing about 5" from the bottom of the back of the frame. Going with smaller tires i have less ground clearance there.
mowerjunkie03
mowerjunkie03
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 14th 2019, 2:07 pm
Lovely build! You've got my vote. What pulley ratio are you plannjng on having?
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 14th 2019, 4:52 pm
Thanks. Im going to be running a 6" on the engine and a 5" on the transaxle. Thats what I ran on the craftsman in my avatar and it worked well.
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 16th 2019, 12:02 am
Ok the fuel system is complete. New carb,fuel pump all new lines, filter and clamps
Also started on the rear bumper there will be lighting to light the back trail my idea will be to light 360 degrees around it so when im working in the trails i will have plenty light. In the middle there will be a brake light if i can find one with a good fit
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190814-201251
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190815-214552
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190815-214910
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 16th 2019, 8:21 am
That rear rack like that will look good!
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 16th 2019, 9:37 am
Oh yeah, that fits perfect!
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 18th 2019, 3:42 am
I know the progress is slow but today I got the rear bumper mounted. Its been a learning session with the stick welder and what amps to weld at. Made a main bumper mount. Its very strong but I might not be done with this bumper yet
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190815-220008
Main bumper mount
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190816-220441-1
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190816-224717
Where im at now with it. Maybe more to come
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190817-215321
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 18th 2019, 3:50 am
Also in that last pic you can see I got the Hydro fluid tank in, its a bit to bright for for me so might tone that down even if its a brushed finish
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 29th 2019, 1:00 am
Ok back with more. Been working hard on this the last week or so. She is finally looking like something.
Here i rounded up material to make the gas pedal
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190820-210826-1
Here they are all cut out and cleaned up
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190820-213402
Cut down and welded this together its what the pedal will pivot on
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190820-223524
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190820-225404
Pedal mounted. Looks like it fits to me
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190820-225859
Started on linkage but need a cable 1st
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190823-214935
Next onto battery mount had to make the bolts longer
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190825-215519-1
Cross bar battery mount
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190825-230614-1
Battery mounted
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190825-232005
Next was to fill this spot on the dash so put swithed here. No cutting of the dash was done
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190823-213832
Switches are in
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190823-214842
Battery door cover made from old DVD player cover. Still needs paint
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190824-223110
And finally got the hood painted and new old stock graphic on Also rear bumper lights mounted
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190828-215759-1
How she sits now. Sorry for lighting I will be taking get out the shop for pics soon. Well guys let me know what you think so far
[FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 20190828-215734-1
PostSubject: Re: [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]    [FINALIST] - Scrap yard murray save [2019 Build-Off Entry]  - Page 2 Icon_minitimeAugust 29th 2019, 10:10 am
She's looking great! Nice job on that foot throttle, definitely looks like it belongs!
» [FINALIST] - Murraymountain's Mountain Murray [2019 Build-Off Entry]
» [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry]
» [FINALIST] - Father Daughter project 2019 Build Off [2019 Build-Off Entry]
» [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
» [FINALIST] - mrshaft696's The Real Horse [2019 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive :: Finalist Archive-
