 [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]
mikeymcc98
8 posters
Go to page : Previous  1, 2
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Empty
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeApril 20th 2019, 2:20 am
Love the steering wheel!!
mikeymcc98
2019 Build-Off Entrant
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeApril 20th 2019, 4:26 am
@prancstaman cheers man didn’t want to use a crap plastic one
J
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeMay 19th 2019, 2:25 pm
Finished the front wheels today I used the original lawnmower rim cut it so it so would fit into the atv rim and drilled  4 holes to match the bolt pattern. Lines up perfect and it’s fairly well centered. I installed heavy duty bearings and added a grease nipple on each side. Cleaned everything down and painted it turned out real nice and is very heavy duty. I also fabricated a double pulley clutch and put on new pulleys which are very heavy duty aswell.[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 2ba94a10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 2efc5610
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 D363a910
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeMay 19th 2019, 2:27 pm
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Fa562810
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 3aaad210
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 8f540c10
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJune 4th 2019, 3:14 am
Ive made a lot of progress over the last few weeks. I fabricated a hood out of steel sheet and cut out 2 rectangles for led headlights I started making a front grill out of rebar and I cut out a section out of the rear hitch plate in order to fit my new mechanical suspension seat because it’s a bit taller than a standard seat. Just did a quick mock up and I’m quite pleased on how it looks. I also stripped down the frame I fabricated and sprayed it gloss black[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Eef60710
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 004afb10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 7249bc10
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJune 4th 2019, 3:15 am
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 74879f10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 E52b0c10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Aad4ec10
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJune 4th 2019, 3:16 am
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 6ce56e10
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJune 4th 2019, 3:17 am
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 B21b0e10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 1b315610
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 2nd 2019, 11:38 am
Progress is looking good! Keep up the good work. Don't forget to keep us updated! Smile
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Sig115PROJECTS:
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Sig214[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Sig314
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 4th 2019, 5:42 am
@MightyRaze thanks been very busy with college lately so havent been able to update as frequently
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 4th 2019, 5:44 am
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 7017f310
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 072d3c10
[Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 D43ced10
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 4th 2019, 5:47 am
Got a good bit done over the last few weeks got the bonnet finished and painted and lights installed. Rear mudguards finished and painted. Got my new mechanical suspension seat painted and installed got the new double pulley clutch installed and new Kevlar belt on its running and drive great now plenty of speed very happy with the progress so far
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 4th 2019, 9:51 am
Looks great!
What's up with your steering?
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 5th 2019, 2:18 am
I like the foot boards, nice setup! And I didn't even know you made your own custom hood! I didn't look through the first page right away. Turned out really nice. Pretty nice spindle braces too. A lot of work involved doing that steering wheel I would think. Having to line it up and weld each link. Nice!
mikeymcc98
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeJuly 5th 2019, 5:00 am
@mr.modified thanks man Yaa putting a lot of time and effort into it but it’s definitely paying off
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeSeptember 2nd 2019, 11:20 pm
[adm]Please update your Build.  It has been a while since we heard from you!  Sad [/adm]
PostSubject: Re: [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]    [Rules DQ] - Mikeymcc98’s Terry the transformed toro [2019 Build-Off Entry]  - Page 2 Icon_minitimeOctober 21st 2019, 10:16 am
[adm]Build in Probation.
Builds that have no update since creation, or several months no update will go into a "Build Probation" folder for not following the rules.
RULE: Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
Builds still in this folder at the end of the build-off will automatically be deemed "Disqualified!" To have your build removed from the Probation, you will need to petition the Admin Team to have it taken back out no later than 30 days before competition end. Contact link is on the bottom of any ATLTF.COM page.
ATLTF Staff [/adm]
» [Rules DQ] - James Yoder's Frankenstein 2.0 2019 build off entry [2019 Build-Off Entry]
» [Rules DQ] - bow tie mud guy's OLD SCHOOL [2019 Build-Off Entry]
» [Rules DQ] - WH-guy's Wheel Horse [2019 Build-Off Entry]
» [Rules DQ] - Josh - project unknown [2019 Build-Off Entry]
» [Rules DQ] - bow tie mud guy's FXT oval track racer MISTRESS! [2019 Build-Off Entry] *
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive-
