| [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] | |
+18Murraymountain prancstaman TheRainbowBoxer diddie mr.modified Stretch44875 redzz02 Double W Cross Ranch muddstir AllisKidD21 Hillbilly Offroading Crazy_Carl mowerjunkie03 MatthewD TheBeal SebastianAlbrecht MightyRaze CraftsmanQuad19 22 posters |
| Subject: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 22nd 2019, 6:36 pm | |
| So here it finally is, time to get off my arse and start building. This is a 1991 craftsman lt4000. I plan to run it at haspin which means it needs lots of work in relatively short time. It will be getting: Lowered fenders Front independent suspension Steering box off a cub cadet Roll cage under the dash and hood Locked peerless 820 with aftermarket final drive Deck raise lever shifter Reinforced frame 18 horse vanguard Pulley swapped (little more than 1:1) 18 inch kenda pathfinders Led lights Paint Full wiring harness Recoil pull start Double barrel ATV exhaust Foot pedal with cruise control cable Remove the governor from the engine Undecided mods are: Exhaust “cutout” Rear facing LED lights Hydraulic disk brakes (front will have drum brakes from the mini quad) Paint color (I have an idea but not set in stone) I plan to run the craftsman hood at haspin, but that isn’t my main goal. End goal is either my Murray hood like @mightyraze has on Kal, or a true craftsman square body hood. Just depends on what I have when the time comes. I’m sure there are other small things I’m forgetting but work will officially begin tomorrow. Approved: MightyRaze 2-22-2019 | |
Age : 23 Join date : 2018-02-27 Points : 3848 Posts : 1299
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5719 Posts : 1402 Location : Central PA
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 23rd 2019, 11:48 am | |
| - SebastianAlbrecht wrote:
- Looks like a Great Build! TONS OF MINTY PARTS!!!
excited how that thing will turn out!!! Oh I’ve been collecting for awhile Goal for today is reinforce the front half of the frame, remove the old axle and steering, as well as anything mower related. Don’t need any of that garbage. Bonus for today would be getting the suspension mocked up and seeing how it will fit around that big vanguard but we will see how far it goes | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2598 Posts : 342 Location : Burnt Ranch, California
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5335 Posts : 2561 Location : Rochester, New York
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 24th 2019, 1:25 pm | |
| - CraftsmanQuad19 wrote:
- 13 inch trans mounts...I assume that is width between the mounting bolts at the axles?
What is it about them that makes them weaker? Yes width between mounting holes. There more likely to belds side to side and they dont have the L shape that sits flat against the trans. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 24th 2019, 2:03 pm | |
| Gotcha. Well I guess I picked well then. There were several of these tractors at the lot, and I picked one that was complete, the sheet metal was all straight and intact, and had a clean frame that didn’t have oil all over it. I had never realized there was any difference in the transaxle mounts in these tractors. Very good tidbit of information there! | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 24th 2019, 6:25 pm | |
| Minor update, got the transaxle gussets welded up. Muffler cut off the engine, and that’s about it. Ran out of welding wire so had to run to Lowe’s and pick more up. Really liking that Lincoln wire. Much better than the Chicago electric wire that came with my welder, or the Hobart wire from TSC | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2855 Posts : 582 Location : Reeses Mill, WV
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 25th 2019, 11:23 am | |
| - Jeremiah R. Cooper wrote:
- That's definitely going to be a beefy frame.
Hopefully! Just stick some angle iron to it and hope it’s stiff enough lol Kind of at a standstill until I run up to my grandmas next weekend and get more supplies. Some rebar to reinforce the back TVP part of the frame, and more angle iron to finish the front. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 25th 2019, 11:28 am | |
| Should be a good build! I'm interesting to see how you're gonna make the Ross steering box work with the ATV front end. I bet it'll be a nice setup! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 25th 2019, 12:31 pm | |
| - AllisKidD21 wrote:
- Should be a good build! I'm interesting to see how you're gonna make the Ross steering box work with the ATV front end. I bet it'll be a nice setup!
Ya I forgot you were using A arms that is gonna be interesting. All the atv suspension conversion I have seen are either direct steer or rack and pinion. | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 25th 2019, 12:42 pm | |
| I think a steering bell crank for the tie rods would possibly work. Like have a drag link off the pitman arm turn the bell crank, and keep the dual tie rod setup. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] February 25th 2019, 1:01 pm | |
- I think a steering bell crank for the tie rods would possibly work. Like have a drag link off the pitman arm turn the bell crank, and keep the dual tie rod setup.
Bingo. The only variables are space and I’m not going to have any idea on that until the engine is mocked up into place with the pulley I will be using, and a belt on it so I know what all I will need to dodge lol Going to do equal length tierods to keep bump steer to a minimum, and the wheel base will end up about 3-4 inches longer overall I’d guess. Using the factory notch for the front axle as the notch for the tierods. Not sure exactly how much load will be put on the shocks or even what they’re rated for. I am going to build it all with the springs set to their lowest setting so if the big vanguard and heavy frame compress it too much for my liking I will raise the front a couple clicks. Also will add a couple degrees of caster in there to help take the strain off the a arms since those will be the weakest part. Such thin metal. Tilt them back a little and all the impact will be transferred to the shock absorber | |
