| [DNF] - Mighty's Project MACK [2019 Build-Off Entry] | |
+4AllisKidD21 Crazy_Carl Hillbilly Offroading MightyRaze 8 posters |
| Subject: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 11th 2019, 7:27 pm | |
| I wasn't going to enter this year. I may finish, maybe not. Nov 30 is a long way off and a lot can be done between now and then. Project Mack, because it is going to be the goto tractor for day to day non-mowing needs. Why Mack? I dunno. Sounded good. At this time I do not plan to lock, but I do plan on a minor pulley swap. I will be installing the Murray sleeve hitch I have under my workbench. Other mods I hope to pull out is maybe create an adapter for some of my SEARS items. I do plan on stretching the front like I did on Kal as I like that wheelbase much better. Suspension: Questionable. I also plan on a winch install. I think I will need a push bumper maybe and definite flood lights up front. I do have a mower deck for this tractor. Debating whether to leave the build where I can run the mower deck or not. This is something I need to decide quickly. Parts Pile: 1985 Murray GT Current 18HP opposed vertical Twin. Runs, will it stay? Depends on mowing capability. Peerless 2300 Transaxle. I would like to do some kind of rib tire on front and Ags on rear. Misc odds and ends and upgrades. Original was missing date... -Approved 2/11/2019 DF
Last edited by MightyRaze on November 9th 2019, 11:20 pm; edited 4 times in total | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2855 Posts : 582 Location : Reeses Mill, WV
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 11th 2019, 8:18 pm | |
| - Jeremiah R. Cooper wrote:
- Love the old Murray's. Yes another 2300 on the build off. Utility tractor build with 26x12x12 v-treads would be the bomb. Good luck!
LOL, not really big on the really wide tires but who knows. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5335 Posts : 2561 Location : Rochester, New York
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 11th 2019, 11:00 pm | |
| Great to see ya in the Build-Off again Mighty! Good luck!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2018-02-27 Points : 3848 Posts : 1299
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 12th 2019, 12:13 pm | |
| It's a thing of the devil. And I do not mean the belt twist... It's that stupid double pulley clutch that is up against that footboard brace and the clutch rod so belt changes are a beast. Takes about 30-40 minutes minimum to change these belts. | |
Offroad MudMowers Member
Age : 21 Join date : 2018-01-09 Points : 2602 Posts : 81 Location : Washington
Age : 20 Join date : 2017-06-09 Points : 5494 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 3:24 pm | |
| Nice build! My Deere is kinda similar, you have to remove the rear pulley to get the belt on, too complicated. And the rear belt still comes off lol.
I'd keep the deck an option, personally. You can always remove the deck stuff later if you decide to make it a non-mowing tractor. | |
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 6:23 pm | |
- Nice build! My Deere is kinda similar, you have to remove the rear pulley to get the belt on, too complicated. And the rear belt still comes off lol.
I'd keep the deck an option, personally. You can always remove the deck stuff later if you decide to make it a non-mowing tractor. There's plenty of room to put it on the transaxle pulley. I think this one has a broken pulley. As for the deck. It would need a lot of work now that I look at it. more $$ than I want to put in that. Besides, I have 2 other tractors that mow. I could rig up a 3rd if needed with minimal effort. | |
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 6:53 pm | |
| Don’t sweat it. You’ve got good fabrication experience under your belt. I know you can build a frame from scratch or a sub frame to make this work. As a bonus you could make a frame to make that horizontal oppy work. Remember the guy last year that made his own wheel horse style frame? | |
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 8:33 pm | |
| So... I'm not diggin this frame. Thinking about abandoning this one and reviving the Sasquatch, rename and make it back into a utility build.
It would lend to give the hood back to Li'l Red. | |
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 8:37 pm | |
| Nooooooooooo!! Don't kill the Sasquatch hot rod!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [DNF] - Mighty's Project MACK [2019 Build-Off Entry] February 13th 2019, 10:28 pm | |
| I Love the Idea of the horizontal Oppy with the 2300...
U should be able to reinforce the frame just with some box steel, few braces here & there, and U have a solid frame that wo'nt twist or bend....
I kinda understand that U want to go the minimal work way since I'm pretty lazy........... but it would be a shame to kill the beautiful Craftsman U built few years ago..... | |
