 Northern Ohio mud mower
Mtdmudmower
7 posters
Mtdmudmower
Northern Ohio mud mower Empty
PostSubject: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 3rd 2019, 1:00 pm
Hello everyone. New to this group but not new to off-road mower mayhem. I started when I was I think 19 I will be 37 this summer. I've been working on my MTD for 2 years now. Improving it as I go. I am in the middle of a drive train swap and soon a carburetor swap to a mikuni typeNorthern Ohio mud mower Kimg0010
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 3rd 2019, 3:59 pm
Welcome to the forum! Neat looking tractor you have there, is that a hood off a newer Troy-Bilt? Feel free to start a thread for it!
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 3rd 2019, 5:26 pm
Welcome!
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 3rd 2019, 5:35 pm
Welcome and nice Rig!
Northern Ohio mud mower Sig115PROJECTS:
Northern Ohio mud mower Sig214Northern Ohio mud mower Sig314
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 3rd 2019, 10:33 pm
Love the way that tractor looks, hadn’t even realized it was an older mtd till AK pointed out the newer hood and I looked again and saw it didn’t match the fenders. Just assumed it was a Troy-Bilt mtd
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 4th 2019, 10:50 am
That's a sweet looking tractor! Like the newer hood, nobody uses them because they come with FNRs. Glad to see that, always thought they looked sweet.
Mtdmudmower
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 7:55 am
@AllisKidD21 @AllisKidD21 yes that is a newer Troy-bilt style hood sitting on what's left of a box framed MTD chassis. I do need to start a thread on this thing show everyone what it started out as and how I got here.
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 8:13 am
That sounds like a great idea!   LOL
We all love a build thread!
Mtdmudmower
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 9:22 am
@Double W Cross Ranch can you define what is fnr's?
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 9:48 am
@Mtdmudmower Single speed with reverse MTD rear axle, has a vari-drive instead of a gear shift in the transmission. They're very weak and lots of people hate them.
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 10:10 am
or less detailed...  "F"orward "N"eutral "R"everse.  Smile
Mtdmudmower
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 12:02 pm
So I should share what I've done to that trans. Stock it is not a good candidate for offroad or increasing speed. It was designed for cutting grass and nothing else. For that matter any open diff trans is not ideal for offroad use either. I dumped the vari drive off of it for a straight belt drive with custom pulley ratio. Locked the diff and rebuilt the internals with better bearings and a higher pressure grease to handle the increased load on everything. Had it clocked at 27mph. Ultimately except for a drive belt nothing has broke on it. And mostly that is due to a lack of using the right belt. Really needs a wrapped kevlar corded belt but getting the length right it was cheaper to use cut poly cord belt so I could try the length variations closest to what I calculated.
Last weekend I busted the belt doing donuts in the snow. Still the original belt I went with after some trials. I am dumping off the current drive train for a cvt clutch going through a right angle box then to a chain driven kart axle. Not happy I'm loosing reverse but ultimately I get a better torque curve and better speed range to the wheels than I had previously.
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 3:38 pm
Wow I always wondered how a pulley swapped FNR would do.  Sounds like you found a pretty good pulley ratio for a rally machine and yeah reverse is great to have.
So you're going to bolt a CVT to a vertical shaft motor?  A predator clone could cost less than a good quality RAGB.  The biggest problem I see is guys putting CVTs on engines that have a much higher horsepower than what the CVT is rated for.  This causes the belt to shred and the return of the belt shredding problems.
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 7th 2019, 5:57 pm
Centrifugal clutches don't like to be slipped for very long though, so if you weren't going full bore all the time the clutch would not be very happy. A CVT would work much better for general off-roading as it would have a full range of speeds. Biggest thing would be keeping mud and water out if it.
Mtdmudmower
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 12th 2019, 7:49 pm
It's a CVT clutch I got European race mower guys use them.Northern Ohio mud mower Kimg0110
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 13th 2019, 3:40 pm
LOL I actually never put that together.  I feel so dumb lol   Northern Ohio mud mower 2429134702
Nice CVT!  I like that plan you've got going, why not try to get a right angle box with reverse?  Or a right angle box and a GoPowerSports reverse box?
Mtdmudmower
PostSubject: Re: Northern Ohio mud mower   Northern Ohio mud mower Icon_minitimeFebruary 18th 2019, 8:10 pm
I have a 90 degree box but it has no forward reverse option. It's rather heavy duty too I want my weak link to be the chain drive not the 90 box. I have kicked around the idea of using a trans type 90 degree in the future though.
» Hello from Northern Michigan
» Mower Crawl/Bog in Southern Ohio, this Sunday
» Mower romp Nov 28th new lexington ohio
» Ohio Offroad Mowers Mower Romp Sunday, March 20th 2016, Be there!!
» Hello from Northern Ireland
All-Terrain Lawn Tractor Forum :: New Member Forum :: Introduce Yourself Here!-
