 The 3 Oppigo's
10 posters
The 3 Oppigo's Empty
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 14th 2019, 10:31 pm
Went and picked up a set of triplets to play with tonight.
The 3 Oppigo's 01141910
The 3 Oppigo's Sig115PROJECTS:
The 3 Oppigo's Sig214The 3 Oppigo's Sig314
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 14th 2019, 10:36 pm
I heard you got a pretty good deal on 'em too! :lol!
Sweet score there Mighty, bet you could put them buggers to use in a real cool project. I'm definitely a little bit jealous, haha.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 14th 2019, 10:38 pm
Lucky. I need one for the gt6000.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 15th 2019, 5:07 pm
Oh man that's a beautiful haul.  It's kinda making me drool seeing an oppy that could work on a wheel horse.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 16th 2019, 1:15 pm
Went through the first one.  Middle in the picture above.  It has fresh oil in it.  Turns over easily, had good compression on one side, the other did not.  Went ahead and removed the heads.  Good side looks great.  The bad side has a stuck open intake valve.  Still trying to get it out.  Other than that one valve, I think the thing would light right up.  I have a parts engine I can snag a valve from if I end up damaging the one that is stuck.  Not sure why it is stuck at this time.  I have it soaking.
I hope to dig into the next one today.  Thinking the one on the pic far left.  It seems froze at this time.  We will see.  The one without tins spins nicely already and you can hear/feel the compression.  I wish it had the tins, it appears to be an older generation of oppy.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 16th 2019, 8:43 pm
All righty.... messed with the second engine tonight....
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 17th 2019, 9:01 am
I really like the video editing techniques you've been using lately.  That's exciting to see the horizontal light off.  I didn't see any smoke from the exhuast.  That's good.  Is the starter any easier to get to on the horizontal models?  What do lawn mower batteries cost in your area?
BTW 2000th post cheers
PostSubject: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 17th 2019, 10:46 am
Oh thanks... I changed from using windows movie maker to filmora.  It's a fun app, it costs, but I caught it during a almost half off promotion last year.  They had lifetime for about the price of one-year.  Thought it was worth it for $40.  I enjoy it.
Starter is exactly the same to get to on a horizontal.  I will be going through it later when I do my final go over in the future.  I'll do that when I pull the flywheel to check those magnets.  Personally, I don't have too much problem getting them off even with the flywheel on.  My area... the 230amp ones are about $19.97 and the 340's are about $30 or so for the cheaper ones.  Farm store batteries are $30-60.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 18th 2019, 7:39 pm
Split off these posts from talk about anything. No sense rattling on over there about them, so why not make them their own topic!
I have some pix and updates in a few.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 18th 2019, 8:27 pm
So... popped the flywheel off.  It was one of the easiest.
My diagnosis of magnet falling off was accurate.  5 of them in total fell off.  I checked the others rigorously and they are in place well.  Buffed up the metal and JB welded them back in.
The 3 Oppigo's 01181912
This did have the 2 wire alternator/stator.  The PO had cut the cables, also cutting off the diode.  I do have a diode set that should work fine.  I extended the wires back out and heat shrinked them.  Cleaned it up and saw no damage.
The 3 Oppigo's 01181910
Reinstalled that and now waiting to reinstall the flywheel.
The 3 Oppigo's 01181911
Need to find me a plug set and reinstall a plug down the line.
I was hoping to get the block washed up before the artic air tomorrow, but that did not happen.  Maybe next week.
Before I reinstall the flywheel, I plan to go through the starter first.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 19th 2019, 6:24 pm
Which one is for me? lol!
Im going the hard to way to get a horizontal oppy... I found a parts one half torn apart I got for the sump to bolt onto a 20hp vertical shaft oppy block.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 1:36 pm
I had been looking for one for 5 years. Now I have 3 dropped into my lap!
Engine 2
It is now complete.  There was some rust needed removed and some polishing needed inside the starter.  Greased it and reinstalled it.  Fires right up and is ready for application.
Engine 1
I still need to get that valve out and shaft cleaned.  I can move it in and out about 1/4 inch now, but needs some work.
Engine 3
I'm going to wait a bit to put it on the test bed.  Thinking of putting engine 1 back on.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 3:32 pm
Any of these gonna find a home in one of your sears?
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 4:16 pm
I am highly thinking about the 77 Suburban. The onan in it is old and tired and currently does not run.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 4:21 pm
That’s the one I was thinking of, but I wasn’t sure if you had put a clone in that one too. Thor right?
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 8:22 pm
I think that would be a great choice, I've been looking for one or Diesel for my 73 sears
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 20th 2019, 10:51 pm
Yep that is the one!
The 3 Oppigo's 20150810
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 21st 2019, 7:39 pm
Engine 1 start test!
Got the valve unstuck and polished a bit.  I will go ahead and pop the flywheel and take out the starter and go through it.  It needs a little cleaning.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 21st 2019, 8:01 pm
That's another one that sounds great, didn't smoke, and would make a great candidate to do a once over on.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 21st 2019, 9:17 pm
Yup, already doing my second level checking.  Pulled the flywheel and starter this evening.  Magnets are all on SOLID on this one.  I noticed there was a stuck nut on the starter with a cable attached.  I checked and sure enough the starter End Cap Brush Assembly was busted inside.  I have a new one pretty cheap on the way.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 23rd 2019, 8:39 pm
I can't seem to shake this idea with one of those Oppys?
The 3 Oppigo's Carsan10
Dang you carsandcameras......
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 24th 2019, 8:24 am
There a few things I love and hate about that build from cars and cameras.  However, I think that is a cool concept with the live axle swap.  I've seen some people here on ATLTF do that and if you did that with a horizontal oppy that would be friggin sweet.
PostSubject: Re: The 3 Oppigo's   The 3 Oppigo's Icon_minitimeJanuary 24th 2019, 9:13 am
Few factors keeping me from it.
Cons:
A. I would want a torque converter - $$$$
B. I would want reverse and those gear boxes are typically rated at 7hp MAX and they are - $$$
C. I don't have the $$$ for this type of build.
Pro:
A. I could step up my skill
B. It would be super fun
The 3 Oppigo's
