 MTD 5hp chipper shredder
5 posters
TourMax
MTD 5hp chipper shredder Empty
PostSubject: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 29th 2018, 7:23 pm
I've been needing a chipper shredder for a while now. BUt one never popped up locally at a price I wanted to pay. beat up. overused, neglected. Always waaaay than more they were worth.
The other day, an older MTD 5 hp one popped up. 275bucks. Price was in range. It's an older model, where everything is steel. That's a plus. Only things plastic on it are the wheels, the air cleaner cover and the handle on the pull cord. Ser number pegs it as a 1991 model.
I went to look at it. it ran half decent, the owner ran a couple branches through it and it worked. So 250 bucks and it was on it's way home with me:
MTD 5hp chipper shredder Fr_44310
MTD 5hp chipper shredder Fr_44311
It's a typical piece of small equipment for the east coast. Used, not well taken care of and just expected to work until it dies. Not much maintenance, not much care. Just hold out as long as it can and then throw it away. But this old soldier has weathered the abuse well and is still in decent shape, despite what was obviously minimal care. Well, those days are over; I take good care of my stuff and this will be no different. Welcome to a new life.
I fire it up and run a branch through it to get a baseline for how it does (or doesn't) work. Well, it shredded it, but it more beat it to death than chipped it.
I shut it down and haul it into the garage to check the chipper blades. I'm being generous calling then "blades", they are more like flat bludgeoning blocks. Well, they need sharpening, no real surprise there.
You can remove just the blades, but I decided to just split the chipper housing and check everything out for good measure.
The disc is frozen to the engine shaft, so I just decided to leave it be. A puller wouldn't budge it and i didn't want to be pounding on what is actually the engine crankshaft.
There's a smaller mower type blade on the back of the disc to mulch leaves and twigs and that is also dull as the day is long. You can tell as the chipper blades dulled and become less effective, people had started to jam larger and large sticks into the mulching section to chop them up. Result: the light duty blade gets beat to crap.
There's also 12 metal flails that do the final stage of mulching/shredding on the disc. You can tell they've never been touched in eh way of sharpening or maintenance. The profile is damned near worn away on the leading edges. Luckily, they are mirror images front and back, so all I had to do was pull them off, clean them up, lubricate and re-assemble with them flipped around and it's a factory fresh edge again.
Tomorrow I'll sharpen and balance the blades, straighten up a few of the metal bits and put it back together. While doing that, I'll clean it up and put a few other bits back to right.
So 250 bucks and a bit of labor and I've got myself a decent chipper shredder. For it's intended uses at least.It's never going to chip up 4-6 inch branches, but it will work fine for my yard clean up purposes.
Not too shabby.
Next winter, I'll probably pull it apart again and give it a nice fresh coat of paint.
Smile
TourMax
PostSubject: Re: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 29th 2018, 10:54 pm
Well, in my typical obsessive fashion, I couldn’t wait until tomorrow.
I spent the evening tearing the chipper apart. Then grinding, filing and stoning the blades to razor sharp edges. Balance them all and then reassemble the chipper.
So at 11 pm, I rolled the chipper out behind the detached garage and fired it up (nearest neighbor is nearly 3 acres away). Sounds 100x better than it did  before, which I atribute to freshening up the flails, lubricating everything and balancing all the blades.
After it had a chance to get some heat in the engine, I grabbed the other half of the stick I used to test it before the R&R.
Push it in to the chipper feed shoot and.... BRAAAAAPPPPP!
SWEET ZOMBIE JESUS!!!!!
It was so fast and violent it scared the living crap out of me!
The 4 foot long stick (approx 2-3” diameter) disappeared faster than I could follow and it was just.....gone. On the ground at the output chute was just a hint of sawdust,  but nothing else.
Poof! Gone.....like it was just erased from existence...
Where I had to push the stick in to get it to do anything before, it now sucked it in so violently I almost didn’t have time to let go! I was so shocked all I could do was fling my arms out to the sides and away from that pit of screaming death, wondering what the eff just happened!
Barely even slowed the engine down.
So yeah: sharpening the blades and setting thing to right have made it a completely different machine. Well worth the effort! If I wanted, I’d say this machine could now be sold for nearly twice what I paid for it with just a little paint touch up and a wax job. Very, VERY happy with how it turned out.
Smile
Now for an oil change, air filter and new spark plug. Then fog the engine and drain the gas. Off to bed it goes until springtime...
PostSubject: Re: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 29th 2018, 11:22 pm
Sounds like a pretty effective unit!
PostSubject: Re: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 29th 2018, 11:26 pm
Good deal man, now you have a way to dispose of your bod-err...branches. Yeah...branches Wink
SteamNut247
SteamNut247
PostSubject: Re: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 30th 2018, 1:33 am
nice find, I had to repower a craftsman that had a 5hp briggs with 1 in. shaft. Ended up putting a Predator 301cc 8hp gas engine on it.
PostSubject: Re: MTD 5hp chipper shredder   MTD 5hp chipper shredder Icon_minitimeDecember 30th 2018, 1:24 pm
Your last post, was funny as hell, LOL. I made me a chipper, still have too, stored in my shed. Works OK I guess but nothing like you described on how yours works, LOL. I made a blade out of a GM starter housing and welded it to a input disk and bolted it to the crank. Made a 2x4 shoot up to the blades with an edge on the end that helps cut and is mounted on a push mower deck. I tried getting one like yours but the guy didn't want to part with it. Good deal you got there.
