| 1977 sears st8 build | |
+3MightyRaze AllisKidD21 Abryant2004 7 posters | |
| | | | MatthewD Veteran Member
| Subject: Re: 1977 sears st8 build August 29th 2018, 11:58 am | |
| Looking good, love the paintjob! You gonna fit the front grill panel again? | |
| Subject: Re: 1977 sears st8 build August 30th 2018, 6:17 pm | |
| Tractor looks great with the orange and black.
Are you planning on mowing with this? | |
| | | Abryant2004 Member
| | | | Abryant2004 Member
| Subject: Re: 1977 sears st8 build October 9th 2018, 3:39 pm | |
| Quick question this is the size rear tire on it 22x7.5-12 has anyone seen an ag tire that size? | |
| | | AllisKidD21 Moderator
| Subject: Re: 1977 sears st8 build October 9th 2018, 4:03 pm | |
| Love the sleeve hitch setup! Looks like it should work great. I've seen 23" tall Ag tires for a 12" rim, those would work good for ya. You could probably get them in 8" or 10" width. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 1977 sears st8 build October 9th 2018, 4:16 pm | |
| Interesting, so that is why that hole is there on the hitch plate on Kal and the other Murray GT I have. For an actuator.
Also, be sure to check actual sizes of the tires. it may say 24x10x12 but actual size is like 23x9.5x12. Also, you can fudge a little on those sizes. That wheel should be able to handle an 8.5, and the height up to about 25/26 maybe. Just have to be sure on the 12, but I'm sure you knew that. | |
| | | Abryant2004 Member
| Subject: Re: 1977 sears st8 build October 9th 2018, 5:13 pm | |
| Thanks for the help with the tires guys, oh the sleeve hitch i did have to cut a little more out of that hole for the actuator lol. | |
| | | Abryant2004 Member
| Subject: Re: 1977 sears st8 build October 9th 2018, 5:22 pm | |
| I actually forgot I also made a crossover and y pip so that I can have a stack on it now too ill get a pick of that in the morning | |
| Who is online? | In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
