 Ford Wheeler "Ford 100"
Kinky_Dee
RockeyDA
15 posters
RockeyDA
Ford Wheeler "Ford 100" - Page 3 Empty
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 11:36 am
Yeah I would think 90-100 PSI would actually be a good healthy number. Also if you have the proper tools like a piston ring compressor, as CQ mentioned,  re-installing a piston is usually a super straight forward procedure.
was not even aware thats a tool, i use my fingers. i wont go bigger than weedeater motor anymore
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 6:43 pm
i did a comrpession test, about 45PSI
if thats low then i think im gonna try that "Engine Restore" stuff since this ford's oil is black as can be. (i dread changing it, i think im goinna have to jack the tractor up a tree to get old oil out.)
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 7:36 pm
well i went to walmart, grabbed the cheapest high millage 10w30 and a can of that "Engine Restore" guess a before and after video will come. im gonna change the oil tomrrow.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 7:40 pm
A ring compressor can be had for super cheap. Less than 20 bucks. Definitely worth getting
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 7:42 pm
Just so you know, if the engine has an automatic compression release a compression test will not be accurate.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 8:39 pm
uhh, so its normal to be able to easily turn the motor over with little resistance?
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 8:46 pm
Well if it has a compression release there will be very little resistance yes.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 8:53 pm
btw, i think somthing is up, and my last flood out on mount nittany did my rings or something in, normally i just get black smoke when the motor is sputtering, but today i got white smoke on sputters and i would start to sputter and stall out if the path is to bouncy.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 9th 2018, 9:18 pm
the Ford Wheeler spotted in its neutral habitat
Ford Wheeler "Ford 100" - Page 3 PoVFhoN
i took this picture right before i went threw that deep mud hole for the first time. i think it looks good.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 14th 2018, 5:27 am
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 7:29 am
so i got a new motor and if i can get it running its going to the ford wheeler. it has no starter, and is missing parts of the air box and a valve cover, but it has compression.
in this video i also take a look at the tractor i thought had a 600 in it.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 2:19 pm
Nice engine!  Yeah, that mower has the belt twist I was telling you about the other day.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 3:47 pm
"Who the hell hasn't heard of an Allis-Chalmers??"
Hahaha, that guy sounds like someone I would get along with for sure. lol!
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 4:12 pm
I was thinking that too, lol!
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 6:44 pm
I think everyone was thinking that... LOL
Ford Wheeler "Ford 100" - Page 3 Sig115PROJECTS:
Ford Wheeler "Ford 100" - Page 3 Sig214Ford Wheeler "Ford 100" - Page 3 Sig314
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 26th 2018, 9:49 pm
update on this motor
durring the 2019 build off im shifting my attention toward the ford, and if i stick with this motor, i think im putting that trubo out back on it. for now if i do the motor swap im just using the stock throttle and keeping it basic untill build off time. i got alot i want to do to this thing, its so hard trying to only keep it running.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 27th 2018, 1:11 pm
Turbocharger?  Sounds nice, might have some issues though, given the carb.  I believe that is a pressure lube engine, so there wouldn't be too many issues oiling it.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 27th 2018, 2:30 pm
why wold the carb have issues?
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 27th 2018, 4:23 pm
Yeah that's definity not true. I've seen lots of different turbochargers set up on engines with carburetors. You could do a blow through or a draw through set up with it, should work fine. Probably not necessary though, I imagine it had plenty of power as is.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 27th 2018, 5:36 pm
If you bolt a turbo directly to a carb, it doesn't work great.
I understand that it is possible, but it takes a lot of fab work, compared to a fuel injected engine where you can just bolt it to the intake, exhaust, and hook up some oil lines and little things like that.  Not sure that it's worth it.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 27th 2018, 6:11 pm
I'm not really sure why you think there's so much of a difference in fab work, for both you need to make adapters for the intake and for the exhaust as well. Same deal pretty much, as far as fab work goes.
Either way though, it doesn't really matter. That V-twin should be a nice upgrade for sure.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 28th 2018, 5:27 am
i just know, i got a turbo laying around, and i want to play around with it. i seen a video of a guy who had a turbo on a briggs oppy.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 28th 2018, 7:25 pm
things are going well with the krapher
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 28th 2018, 8:07 pm
Single cylinder Briggs engines are 2 bolts+power wire, but yeah the oppies are super hard to change starters on.  I'm surprised about how little the valve covers actually do, I would have thought that it would be spewing all kinds of oil everywhere.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 29th 2018, 4:45 am
i guess oil is supposed to hit the valves? other than that john dere i got 2 days befor that motor, this is my first OHV motor.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 3 Icon_minitimeAugust 30th 2018, 5:04 am
for a get up at 4am job i spent to much time working on this last night. it was dark by the time i was in bed.
Page 3 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Ford Super 34 Snowblower For a Ford 100
» Ford lgt 100 build
» Custom Three wheeler "Little Red"
» Snapper Three-Wheeler Build
» 67' Ford lgt 100 build
