 Ford Wheeler "Ford 100"
Kinky_Dee
RockeyDA
15 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
RockeyDA
Ford Wheeler "Ford 100" - Page 8 Empty
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 7th 2019, 7:47 pm
i got rained out half way threw but im back to trying to fix the front end, even using a firends nice drill gun, my cheepo bits could not go thre the cast iron, i would make a little progress, but was also chewing up my bit.
so were WELDING AGIN. but this time im welding with the knolage i only can make surface welds, no penetration limited stenth. so im using angle iron is bracing, and i will drawl a pic of how im putting them in, but im using the angle iron to hold things together, and welds to keep them in place, and even hold 2 pices together. TO MS PAINT!
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 7th 2019, 7:58 pm
Ford Wheeler "Ford 100" - Page 8 5lf8mFI
red reperesents angle iron, yellow represents welds. already got the angle iron in and 1 pice welded in, the gaps tight enough i had to hammer the angle iron in.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 7th 2019, 8:50 pm
i need to grind that pice of iron sticking out alittle bit, give it something like a 45 so i know it will melt good in to the other pice its contacting.
Ford Wheeler "Ford 100" - Page 8 UTeGOFM
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 10th 2019, 3:16 pm
good news, it served my off camra stress test were i held on to the wheel for my life and floord it threw the tree root rattle zone. if trans did not have bad seals would be ready for trail ride... were can i find 2300 trans seals?
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 15th 2019, 5:42 am
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeApril 24th 2019, 7:45 am
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 8th 2019, 12:03 am
the ford wheeler is coming back to life as the mud train is beginning to sit till i find new piston rings at a price i can afford.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 8th 2019, 12:06 am
so goals as of now!
1. fix dashbord and hood using welded up steel plates and dilling holes for bracing.
2. get a non working kholer starter i have laying arround to work.
3. fit a battery were it would go (shifters in way) and give this thing an electric start already.
when im not super broke bigger pully swap.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 8th 2019, 5:23 pm
AND BACK TO RETIREMENT SHE GOES! i fixed the grill, was getting some angle iron for the dash, on the ride home i suddenly bogged down and stalled out. could got get any life wide open throttle rope starting. so poped air filter off. it was so flooed it was about to spill out of the intake.
the carb always had a leak that made me run to rich and now the spill way has opend. and the crazy stong fuel pump made me have to drive with the fuel off, then on for 1 second, then off about 25 or when ever it statted to sound like it wanted to stall. if i left it on over 3 seconds, game over, even if i shut it off, its gonna dump fuel like crazy.
that fuel pump is so strong i had to put my shut of ahead of the fuel filter, it crushed it like a juce box, and its one of the ones with a metal base.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 9th 2019, 10:36 am
Wow, that sounds pretty crazy. You might want to look into a pulse pump, it is powered by the engine's pulse, and it pumps faster when the engine is going fast, and slower when your idling.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 10th 2019, 10:20 am
all the seals in the carb are crackly and break if you try to move them. float main seal are holding up. but o rings are basically peanut brittle.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 12th 2019, 4:56 am
ok, i think this will hole till my rebuild comes
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 12th 2019, 11:37 am
Are you sure that the fuel pump isn't getting too much power or something similar?
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 12th 2019, 2:28 pm
shouldn't be, 100% stock, unless its abnormal how strong min is, im not a plastic kholer man
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 12th 2019, 2:31 pm
thats the kind of pump it has.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 17th 2019, 8:12 am
ok, this tractor went for its first real trail ride with its current setup. it was a huge fail, i was loosing all my HP to belt slip to the point in the deep mud, second gear slipped to much.
i might do 1 more pully swap and maby play with cluch setup. but i think the ford is going beltless down the road. maby that can be a 2020 build off thing. make the ford not suck.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 17th 2019, 8:17 am
maby i could use one of thoes tractor drive shaft PTO cluches they sell at TSC and mount it right to my crank, put a sprocket on the end of it, have a chain going down alittle, jack shaft, chain running in belt area, jack shaft, chain running to sprocket that would be offset becase they way the 2300 is on the ford. would not be cheep setup.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 17th 2019, 8:22 am
here is a video of how it performed, its a shame, the ford is my best mudder. but between bad trans seals and belt slip it sucks to mud.
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 21st 2019, 3:08 pm
Interesting... Uploaded video that won't let you view until the premiere date.
Ford Wheeler "Ford 100" - Page 8 Sig115PROJECTS:
Ford Wheeler "Ford 100" - Page 8 Sig214Ford Wheeler "Ford 100" - Page 8 Sig314
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeJune 21st 2019, 8:22 pm
the video worked a few days ago, but i decided to do the premiere thing and see how it works out. since these videos normally only gets 3-6 likes.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeOctober 15th 2019, 8:46 am
UPDATE: ford still needs belt and i havent felt like spending 20somthing on one... but im getting the urge to, dont like winter to role around with nothing diriving
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeOctober 15th 2019, 10:07 am
Belts are pricey. Even more so I'd you need a 5/8 belt.
RockeyDA
RockeyDA
PostSubject: Re: Ford Wheeler "Ford 100"   Ford Wheeler "Ford 100" - Page 8 Icon_minitimeOctober 15th 2019, 12:56 pm
and making the front pully bigger without chaining the cluch makes it were i cant have good grip or slip at the same time, holding in cluch smokes belt. but the thing is useless in the mud from slip. thogh that pully on the trans is horrible and i cant swap it unless i redo whole belt setup becase of the pully shape
Page 8 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
» Ford Super 34 Snowblower For a Ford 100
» Ford lgt 100 build
» Custom Three wheeler "Little Red"
» Snapper Three-Wheeler Build
» 67' Ford lgt 100 build
