| Pipe bending. | |
| Subject: Pipe bending. May 2nd 2018, 1:21 pm | |
| Anyone got any good tips or tricks bending pipe when you do not have a pipe bender or someone with one you can borrow?
Age : 35 Join date : 2017-10-30 Points : 5335 Posts : 2561 Location : Rochester, New York
| Subject: Re: Pipe bending. May 2nd 2018, 1:27 pm | |
| anneal it with a torch or get it red hot first | |
| | | AllisKidD21 Moderator
| Subject: Re: Pipe bending. May 2nd 2018, 1:43 pm | |
| I usually do the botch, bennd, and weld method. Worked great for everything I've done. Then the welds can be cleaned up with a grinder afterwards. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Pipe bending. May 2nd 2018, 2:41 pm | |
| - Crazy_Carl wrote:
- anneal it with a torch or get it red hot first
That's the best I'm thinking at this point. I do not need a 90*, more on the lines of 120-130*. \__ | |
| Subject: Re: Pipe bending. May 2nd 2018, 3:33 pm | |
| depends on where you measure if from | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
| Subject: Re: Pipe bending. May 2nd 2018, 6:19 pm | |
| You can get quite a good bend if you fill the pipe with fine sand and heat it up and bend it. There shouldn't be any kinks because the sand should keep the shape. | |
Age : 34 Join date : 2013-11-02 Points : 7171 Posts : 2910 Location : New Jersey USA
| Subject: Re: Pipe bending. May 2nd 2018, 8:32 pm | |
| I buy pre bent 90 degree sections from lowes/home depot. 1" electrical conduit. They aren't the tightest bends but they're usable for some stuff. If you want less than 90 of course you would cut out the section you need and weld it in. My simplicity exhaust is made from that except right where it goes to the engine. That tighter bend was another exhaust I think. Or maybe it wasn't, I'd have to look at it. | |
| Subject: Re: Pipe bending. May 2nd 2018, 9:36 pm | |
| lots of good info... I think I am leaning towards what @mr.modified said for what I needed. Bending would be nice. | |
| | | | | Pipe bending. | |
