Most mowers have a giant flaw, they put the cup holder on the same side as the discharge chute, so unless you have closed top you get a grassy drink. LOL
Age : 49 Join date : 2016-09-06 Points : 15679 Posts : 10988 Location : Oklahoma
On the old john deere Bs back up in new york, just about every one in our family had a Maxwell House coffee can bolted to the side of the dash. Tractors back in 1940 didnt exactly have user comforts like cupholders lol
So, here's some old footage of riding Nellybelle. The head broke off the shifter, so I just put it into gear with a wrench and wasn't going to shift. The battery was dead, so it was hard to start, but the main issue is the solenoid fell off the bottom of the carb. The threads are stripped out, so I at least need a carb. Anyway, here's the footage. https://photos.google.com/photo/AF1QipPhA3BoaIXGGVt3y3B54xZHw006hZMHqFx0vL-R (For some reason YT just won't upload it, IDK.)
I'm putting different fenders on it cause I can't stand the stock Craftsman fenders, and I plan to put a new bumper, big aggressive lights, and new front tires. I'm lowering the seat in the rear and relocating the battery. Since I need to replace the carb, I'm thinking of a Mikuni (I doubt that's spelled right),and then putting a snorkel on that.
Should be pretty good, if you have any idears, throw 'em out!!!
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3564 Posts : 825 Location : In the shop
I hate the lt1000s bodywork and then the lt6000 has my favorite look ever. And my lt4000 is in between. I like the fenders but i'm not a huge fan of the hood.
Age : 20 Join date : 2017-06-09 Points : 5495 Posts : 2640 Location : Literally Nowhere, Texas
A nice heavy duty solid axle front suspension setup would be cool too. Hahaha, I kid I kid. Although IFS woulda maybe worked better for what youre doing.
Okay, I'm gonna preface this with saying I know I'm crazy. I want a diesel engine in NellyBelle. They don't make vertical shaft Diesel engines, so I can't buy one, plus I don't have the money. I've thought about the differences between a gas and a diesel engine. No spark (easy, just pull the cap of the plug), more compression (I'll have to study on that, might be hard to get enough compression), a glow plug, and no carb. Her carb is already bad, sooo.... Found a video on someone who tried to do something similar.
Does anyone else think it's possible, or is it crazy dangerous, or what. Lemme know.
Age : 25 Join date : 2016-07-10 Points : 8590 Posts : 5190 Location : Ontario Canada
They actually do make vertical shaft air-cooled diesels, I've seen V-twins which is awesome. They are very hard to get a hold of. For what it's worth I'd say the conversion would be a lot of effort just to say you have a diesel engine. The stock crank, rod, head, block, etc would most likely not hold up to the compression required to make a diesel engine run. Also you wold have to figure out some sort of injection system be it mechanical or EFI. Obviously it's your call but I say it probably ain't really worth it.
Yeah, I figured it would be a lot of work. Hadn't thought about the structural integrity of the rod and the crank. Like I said, it is a crazy idea. I think I'll keep it gas, but if I get the chance to buy a diesel, I will. Also, if you can convert a vertical shaft to a horizontal shaft, how come people don't convert a horizontal to a vertical?
