Went to the deepest part of the swamp, it was partially floating. I think the tracks were partially touching the bottom whenever I shifted from side to the other. No other leaks though after fixing that one!
One thing I noticed too is the steering brakes don't grab real well when they've been submerged for awhile. Gotta do shallow turns to dry them off, after they dry, it does well. A price for economy and simplicity I suppose.
frostypaws Member
Age : 30 Join date : 2012-07-01 Points : 4689 Posts : 131 Location : iowaaaa
Did some drawbar testing last night to test the hydraulic cylinder concept. 1,459 lbs of static drawbar pull.
Old cylinder dimensions: 3" bore x 1-1/4" rod Soil Conditions: Semi-saturated vegetated sand and loam
Haven't measured the weight yet of the machine to give an accurate drawbar pull/vehicle weight ratio, but right now I am probably under 1. I think 3/8" grousers might get me to the 1:1 ratio I am looking for.
Just curious, has anyone measured the drawbar pull of their wheeled tractors with ATV tires?
frostypaws Member
Was able to get one coat of primer on this week. Next 10 days arent looking good temperature-wise, so I don't know when I will be able to spray the rest.
I like the front tow hooks. I don't remember seeing those before. I'm pretty since this thing is a tank you'll have to go with some kind of olive drag or dessert tan color for the top coat. Or maybe a white and black winter camo pattern?
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3561 Posts : 825 Location : In the shop
So I put the first top coat on today and ran into a little issue, in some areas the paint is cracking when it drys. I think it is a cleanliness issue because the writing from the steel paint markers also bled through from the plates. I'm guessing when I start my second coat I can sand these areas down, re-clean and reapply paint?
TheBeal wrote:
I hpe that wasnt a rattle can paint job. Thada taken a while!
Haha, nah I used a harbor freight HVLP gun hooked to my 20 gallon compressor. This is my first time spraying paint, it definitely is an art with getting the right viscosity and pattern. Right now it looks like a Russian Navy paint job! I'm sure with experience I will get better!
Thanks. I should post some pics of the Mark II updates. The color I picked up was 'Jon Boat Green'. It was the closest paint I could source locally that matched the color of old Soviet Iron
A good paint job really comes down to how much prep work you put into it. At a minimum I usually hit all surfaces with a wire wheel on a grinder or drill and wipe the whole thing down with lacquer thinner before paint.
are you planning on roofing on some of it so the swamp splashes and rain don't get in.
Eventually I would like to build a cab, haven't decided if it will be a hard or soft-top. I'm thinking the latter. However, when I cab over the machine I have to think about where all my radiator heat will go. Mr. Modified suggested using a remote radiator with electric fans so I can mount the rad to the side, which isn't a bad idea.
I missed the step with cleaning with thinner . I'm new to the whole painting side of things, so I will be learning alot when it comes to detailing.
Got the 2nd top coat on today while the weather was as close to 50° for the next week. It's definitely not the best paint job out there but I kinda like the roughness of it, gives it character.
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
