| $20 Poulan Pro Project Mower | |
+4prancstaman CraftsmanQuad19 AllisKidD21 TN_Murray 8 posters |
| Subject: Re: $20 Poulan Pro Project Mower December 14th 2017, 8:56 am | |
| I agree with CQ. Looks to be quite a bit of weight hanging off the exhaust bolts. Looking good though! | |
| Subject: Re: $20 Poulan Pro Project Mower December 14th 2017, 9:28 am | |
| I wonder if that strap going through the foot-board is the mount for the exhaust? Just at the end of the rubber mat part and the bend. Only think I can think of, is when you change your oil, it might make a bit of a mess with the pipe under the drain. PS, you can use that deck lift as a hand brake! | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4932 Posts : 1944 Location : Kansas
| Subject: Re: $20 Poulan Pro Project Mower December 14th 2017, 4:03 pm | |
| I used the deck lift on my murray to control the breaks, and i can lock the tires up completely going about 25 mph from the torque i can put on the breaks now. | |
TN_Murray Member
Age : 28 Join date : 2017-11-03 Points : 2611 Posts : 27 Location : Lexington TN
| Subject: Re: $20 Poulan Pro Project Mower December 18th 2017, 11:01 am | |
| Will definitely add the support. Have plenty of scrap metal where I work. Thanks for the suggestions so far have definitely been trying to incorporate them into this build. Now how would the 2 rear pods work for brake lights? Just wire then up like I would my headlights and flip a switch for when they're needed or have them light up when I mashed the pedal? | |
| Subject: Re: $20 Poulan Pro Project Mower December 18th 2017, 11:32 am | |
| it would be easier to control a switch for on /off then wiring up a brake wiring system, and for off roading its nice to have light all around if your going to be driving a lot at night so the brighter the better in my opinion . | |
| Subject: Re: $20 Poulan Pro Project Mower December 18th 2017, 11:45 am | |
| - TN_Murray wrote:
- Will definitely add the support. Have plenty of scrap metal where I work. Thanks for the suggestions so far have definitely been trying to incorporate them into this build. Now how would the 2 rear pods work for brake lights? Just wire then up like I would my headlights and flip a switch for when they're needed or have them light up when I mashed the pedal?
If you wanted true brake lights, I have used the clutch/brake safety switch to wire up brake lights a few times. | |
| Subject: Re: $20 Poulan Pro Project Mower December 18th 2017, 11:49 am | |
| Would it be good for the L.E.D light pods to be switched on and off ? they are designed to warm up and be kept on i thought. Break lights are designed for that start stop action. | |
| Subject: Re: $20 Poulan Pro Project Mower December 18th 2017, 11:56 am | |
| I have LED brake lights for a Harley on my sasquatch tractor. You are talking about your pods, I agree with your assessment to "switch" them. | |
TN_Murray Member
| Subject: Re: $20 Poulan Pro Project Mower December 19th 2017, 8:53 am | |
| Thanks guys! Just to keep things simple I think I'll go with the switch route alot less to fool with. Now what pulley ratios are yall running on your rigs. I don't need to run 20 mph but faster than stock speed would be nice
| Subject: Re: $20 Poulan Pro Project Mower December 19th 2017, 9:20 am | |
| I think a 1:1 would be a good start, Maybe a 5 and 5 or 6 and 6 pulley. That would get you up around the 20 mark, but still have some good power in your low gears. I'll let the other guys chime in, get a bit less slippage on the 6's, but can you get one that size up under the motor without a lot of work? That's up to you. | |
| Subject: Re: $20 Poulan Pro Project Mower December 19th 2017, 11:06 am | |
| i have a 6 to 6 inch ratio on my murray with 22 inch tires, might hit about 24 mph but it is ungoverned so that speeds it up quite a if your going 1:1 ratio try to get bigger pulley diameters so you woulnt need a big clutch spring but will have less slippage without stretching your belts super tight.( my craftsman is getting 10inch pulleys for maximum belt contact since i am planning very aggressive tires when i get a 820 peerless | |
| Subject: Re: $20 Poulan Pro Project Mower December 19th 2017, 12:20 pm | |
| I run 4.75 front that's for a 5/8 belt, and a 4 inch rear for a half inch belt, and run a half inch belt. The deeper groove in the front just keeps it from jumping out easily. Runs about 15 MPH governed, high 20's, maybe low 30's with the governor overridden | |
TN_Murray Member
| Subject: Re: $20 Poulan Pro Project Mower December 20th 2017, 6:19 pm | |
| Thanks guys, I think I'll go with 6 to 6 I still use the mower for pulling around the yard and still want good low end power | |
TN_Murray Member
TN_Murray Member
| Subject: Re: $20 Poulan Pro Project Mower December 22nd 2017, 12:40 pm | |
| Sucks about your transaxle. Did it split the case or something? Some damage pictures would be cool, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: $20 Poulan Pro Project Mower December 22nd 2017, 12:43 pm | |
| i bet it split the case, the peerless gears on 206's are pretty good and the aluminuim is the weak part around the diff | |
