| Ford lgt 165 /craftsman lt4000 | |
+2AllisKidD21 hotrod-craftsman 6 posters |
hotrod-craftsman Member
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 26th 2017, 12:21 pm | |
| Thanks for the info it does have the H pattern, what transmission would be better the peerless 2300 or the roper 633? | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 26th 2017, 12:26 pm | |
| Both are really well built, but I would assume the 2300 since the case is cast iron instead of aluminum. But gotta remember that adds weight | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 26th 2017, 12:38 pm | |
| Well actually in that new of a tractor it will be the AYP version of the 633a, which is called a 122x series or something like that. A little bit lighter duty than the old 633a's, but still really tough! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2017-08-26 Points : 2701 Posts : 51 Location : omaha nebraska
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 26th 2017, 12:54 pm | |
| Ok thanks for the info it does not have a did lock but would it have independent brakes? Or would you have to mod that. | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 26th 2017, 12:59 pm | |
| You would have to mod that. @mr.modified made some interesting brakes that you could easily make separate of each other. They are on his Simplicity adventure edition. He can explain them better than I can but they worked well from what I understand | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5719 Posts : 1402 Location : Central PA
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 6:15 pm | |
| - hotrod-craftsman wrote:
- since my budget is limited I have a few other tractors I’m looking at but would rather take the ford.
Mind my asking what else you are looking at? | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 9:56 pm | |
| Not really anything just got the photo of the engine, gunna be a let down for everyone thinking apossed twin kohler | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 9:59 pm | |
| Ooh a V-twin! Nice! So you thinking about pickup the Craftsman then? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 10:00 pm | |
| It’s a kohler command, still in my opinion a great engine, have the exact engine in my John Deere gunna ask him a few more questions then hopefully I’ll have it sat or if I can’t get it then Wednesday next week | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 10:02 pm | |
| Nice man!! What are your plans for it? Workhorse? Off-roader? Mudder? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 28th 2017, 10:06 pm | |
| Gunna be a fuse between a workhorse and a mid range racing mower, aka high low shifter, since our farm needs a tractor that can pull a few hundred pounds at a time up hill usually a 30-40 degree angle this tractor will be perfect. I have this tractor (or one similar) it has a strait shift but needs to be replaced due to heavy frame, hood, and engine damage, also the head gasket if broke from the cylinder to the valves, and from the valves to the outside, I put 2liters of oil all gone in at least 5 days because the leaking is so bad. | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 29th 2017, 3:22 pm | |
| Bad news the guy for the craftsman he wants more that what my budget affords so I can’t even get if for my limit of 400 so I had a backup witch I’m looking into a John Deere 214 | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 29th 2017, 8:33 pm | |
| Yep lots of patience, I’m looking but the few I find are two far away. Recently found a John Deere 214 with a Chrome exaust but also to far. | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 September 30th 2017, 9:47 am | |
| - since our farm needs a tractor that can pull a few hundred pounds at a time up hill wrote:
For what its worth, and Im not sure how much was in the wagon... but my sears dont pull uphill well. I dont have wheel weights so that might have been my problem. Just something to think about. | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 October 5th 2017, 4:08 pm | |
| Good news I have found a John Deere 300 with dual hydros and a snow plow, currently talking to the guy but I hope I can get this one. | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 October 5th 2017, 4:52 pm | |
| Ooh, nice. Got any pics of it or was it a local thing? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 October 5th 2017, 4:56 pm | |
| It’s for sale locally but here’s a photo
Last edited by hotrod-craftsman on October 5th 2017, 4:57 pm; edited 1 time in total | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 October 5th 2017, 4:58 pm | |
| Aw cool! What's he asking for it? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ford lgt 165 /craftsman lt4000 October 5th 2017, 4:59 pm | |
| There is no mower deck but I could find a mower deck for a 318 pretty easily and just put it on it. He’s asking 1100 but he’s open to any offers he hasn’t got back to me but I said 500 cash and I have 2 tractor without engines if he wants one. | |
