| Ever seen one of these? | |
Alaskan Craftsman Member
Age : 38 Join date : 2015-12-17 Points : 3318 Posts : 44 Location : Anchorage, Alaska
| | | | AllisKidD21 Moderator
| Subject: Re: Ever seen one of these? July 11th 2017, 8:43 am | |
| My rat rod Toro used to have one of those pressure clutches on it. The friction lining was too worn for it to work though so I had to weld it up solid and build a double pulley clutch for it. I'd much rather have one of those though because you could have a lot of belt tension and not have to worry about the belt grabbing when you press the clutch in. I'm not sure how easy it would be to get parts for one. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ever seen one of these? July 11th 2017, 3:22 pm | |
| - AllisKidD21 wrote:
- My rat rod Toro used to have one of those pressure clutches on it. The friction lining was too worn for it to work though so I had to weld it up solid and build a double pulley clutch for it. I'd much rather have one of those though because you could have a lot of belt tension and not have to worry about the belt grabbing when you press the clutch in.
I'm not sure how easy it would be to get parts for one. As for a new pad there are no parts but i can buy 3.55mm sheet of pad and cut my own clutch pad from it. luckily my clutch is still super good and it grabs like a mofo. | |
| Subject: Re: Ever seen one of these? July 11th 2017, 6:09 pm | |
| Nice hahaha. I kinda wish I'da kept mine, they're a pretty neat setup. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Ever seen one of these? July 11th 2017, 11:42 pm | |
| True. But that's pretty easy to prevent Doug, just put a sticker near the transaxle that says "No Dirt Allowed!" and it shouldn't be a problem. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ever seen one of these? July 11th 2017, 11:45 pm | |
- Nice hahaha. I kinda wish I'da kept mine, they're a pretty neat setup.
yeah i would love to have a clutch set up like that on lets say a 633 lol. half of me says just use it as a mower and the other half of me says lift it and romp it. | |
| Subject: Re: Ever seen one of these? July 12th 2017, 12:03 am | |
| Or RAT ROD IT! Haha, just kidding. These things have like a C-channel frame most of the way back and a fairly heavy duty (And unusual) steering setup. So I'd imagine it would make a pretty good off-roader. The part of the frame that houses the transaxle is kinda flexy though when ya go over bumps, so a crossmember or two would help a bit. Also mine has had a Peerless 600 swapped in place of original 5-speed, so that adds to the heavy-duty...ness. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Ever seen one of these? July 12th 2017, 1:24 am | |
| yes the steering is one of a kind with its drill bit style threaded sleeve lol. its funky but well built. 25s and 18s would be nice lol but on the other hand its a really nice mower. | |
| Who is online? | In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests
