| | John Deere LT133 Build | |
SullyBumkin New Member
![SullyBumkin](https://2img.net/u/2812/37/66/46/avatars/1622-26.jpg)
Age : 37 Join date : 2014-03-24 Points : 3839 Posts : 12 Location : Clifton Forge, Virginia
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: John Deere LT133 Build March 3rd 2017, 5:54 pm | |
| While out of town on business, I stopped by a junk yard that advertised having almost every model of JD lawn and garden tractors ever made. With the exception of a couple rare models that I never found, he was pretty accurate.
(This is just one of five areas full of Deere and other makes of lawn and garden tractors)
After HOURS.... Yes, hours of combing the piles of green treasure, I came acrossed several possible project tractors. With the others waaaay out of my price range (even after some wheeling and dealing), I headed home with a JD LT133. Not exactly my first choice when I arrived at this glorious facility, but its one that agreed with my budget and having the geared transaxle was a plus.
(Day One)![John Deere LT133 Build Day_Two](https://2img.net/h/s19.postimg.cc/mf3locl43/Day_Two.jpg) I'll try to keep everybody updated as the project progresses!!
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 3rd 2017, 8:36 pm | |
| Very cool find. I see your post count is low, Welcome to ATLTF! Keep us informed of your progress. There are some smart people around here to poke questions at. | |
| ![Go down](https://2img.net/i/empty.gif) | | SullyBumkin New Member
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Day Two March 3rd 2017, 8:51 pm | |
| (DAY TWO)
After some extensive tinkering, I got the motor to run under its own fuel delivery. I replaced the torn up seat with an extra I had laying around and added 2" receivers front and rear from a parts tractor. Also, the rears were swapped for Carlisle HD Field Trax's ( 22x12-8 ) and the fronts were changed to Carlisle X-Trac's ( 15x6.00-6 ). Even though the X-Trac's are designed for snowblower applications they really look good with the oversized Field Trax's.
After a test run though the woods, I am more than satisfied with the tires and how they perform. The front tires really bite in good in just about any terrain I tackled with it. (After the test run)![John Deere LT133 Build S_l1600_4](https://2img.net/h/s19.postimg.cc/i0v4ciajn/s_l1600_4.jpg) ![John Deere LT133 Build S_l1600_1](https://2img.net/h/s19.postimg.cc/db56nwjj7/s_l1600_1.jpg) (Carlisle HD Field Trax) (Carlisle X-Trac & Front Receiver)![John Deere LT133 Build S_l1600](https://2img.net/h/s19.postimg.cc/xc9iqux9f/s_l1600.jpg) Next on my list of things to do:
1) Motor Pulley Swap 2) Foot throttle 3) Figure out a hood
| ![Go down](https://2img.net/i/empty.gif) | | CraftsmanQuad19 Veteran Member
![CraftsmanQuad19](https://2img.net/u/2812/37/66/46/avatars/2588-88.jpg)
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 3rd 2017, 9:01 pm | |
| Hey I have one of those! ...I'm not a fan of it honestly. Too complicated and it has a Foote rear end instead of a peerless. I'm selling it as soon as I get it running....
On a happier note, welcome to the forum lol | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 3rd 2017, 9:11 pm | |
| - CraftsmanQuad19 wrote:
- Hey I have one of those! ...I'm not a fan of it honestly. Too complicated and it has a Foote rear end instead of a peerless. I'm selling it as soon as I get it running....
On a happier note, welcome to the forum lol Thanks for the warm welcome.. LOL
I've actually been a member for a couple years, just never posted anything I was building till now.. As for the LT133, I'm really thinking of swapping the Spicer for a peerless, just not really sure which one is best. I am open to all suggestions. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | MightyRaze Administrator
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | SullyBumkin New Member
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 3rd 2017, 10:05 pm | |
| - mightyraze wrote:
- A John Cadet doesn't look too bad!
Thank you. I thought it looked pretty good myself. Hopefully i'll get it mounted sometime this week. | |
| ![Go down](https://2img.net/i/empty.gif) | | MatthewD Veteran Member
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 4th 2017, 7:12 am | |
| Looks really good with the Cub hood! I see you've got the clutch/brake pedal on the right-hand side. Makes it tricky when you want to add a foot throttle. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 4th 2017, 1:40 pm | |
| - MatthewD wrote:
- Looks really good with the Cub hood! I see you've got the clutch/brake pedal on the right-hand side. Makes it tricky when you want to add a foot throttle.
Thanks. I really took a chance on that Cub hood fitting or even looking good on the Deere, but it definitely worked out. As for the foot throttle, i'd like add a clutch pedal on the right side and leave the existing one there as a foot brake. Maybe trim up the pedal slightly to add the foot throttle on the same side as the brake. Any advice or ideas are welcome. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 4th 2017, 5:12 pm | |
| Good idea. I'm planning on doing the same thing on my Westwood project ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 4th 2017, 11:24 pm | |
| Just throwing an idea out there, maybe re-bending that pedal to be a little higher and closer to the dash tower, and mount a gas pedal from the outside-in at a slightly different level? All kinds of ideas would work I think. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 5th 2017, 12:00 pm | |
| - mightyraze wrote:
- Just throwing an idea out there, maybe re-bending that pedal to be a little higher and closer to the dash tower, and mount a gas pedal from the outside-in at a slightly different level? All kinds of ideas would work I think.
That's a good idea. However, I'm 6'-6" tall and it might make it harder for me to transition from the throttle to the brake. If I can figure out how to make a clutch pedal on the opposite we'll be in business. If not, i'll have to put the throttle on the left side and keep the brake/clutch combination on the right side (which I'm not a huge fan of). There has been times where I tried to stop and was stomping on a clutch pedal that wasn't there. LOL. Definitely is an odd set up. Not exactly sure why Deere did it like that on these models. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build March 5th 2017, 9:41 pm | |
| I have a Craftsman LT4000 all-wheel steer that has the clutch/brake on the right and a deck lift pedal on the left. I can't tell you how many times I hit the lift instead of the brake. | |
| ![Go down](https://2img.net/i/empty.gif) | | Crazy_Carl Veteran Member
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | Subject: Re: John Deere LT133 Build November 8th 2017, 2:51 pm | |
| Any updates on this? I'm looking to gather ideas for my JD LT160 build. I like the way that hood looks on there. | |
![John Deere LT133 Build Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | John Deere LT133 Build | |
| Who is online? | In total there are 93 users online :: 0 Registered, 0 Hidden and 93 Guests
