| Mud bash jeep for local mudrun | |
+6prancstaman mr.modified CraftsmanQuad19 TheBeal jimtolken ballsdeepmudmowers 10 posters |
ballsdeepmudmowers Member
Age : 27 Join date : 2016-12-01 Points : 3114 Posts : 181 Location : Allegan Michigan
| Subject: Re: Mud bash jeep for local mudrun April 19th 2017, 12:54 am | |
| Got new tires old ones looked too small Was going to use these but they are in bad shape Got these bad boys instead 35s ftw | |
| Subject: Re: Mud bash jeep for local mudrun April 19th 2017, 10:29 am | |
| Looking pretty cool man. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Mud bash jeep for local mudrun April 19th 2017, 1:39 pm | |
| Thanks had it running today on it's own (mason jar for a gas tank ) and it sounded good now to make sure it stops and hook up throttle | |
Age : 49 Join date : 2016-09-06 Points : 15676 Posts : 10987 Location : Oklahoma
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5718 Posts : 1402 Location : Central PA
| Subject: Re: Mud bash jeep for local mudrun April 21st 2017, 8:24 pm | |
| So, the louvers there, were they just part of the material scavenged from something else? Or were these custom made? | |
| Subject: Re: Mud bash jeep for local mudrun April 21st 2017, 9:57 pm | |
| - TheBeal wrote:
- So, the louvers there, were they just part of the material scavenged from something else? Or were these custom made?
They where in the material I think it was part of a furnace or stove of some sort | |
| Subject: Re: Mud bash jeep for local mudrun April 22nd 2017, 9:58 am | |
| So, it might be wise to reinforce the spring shackles. I imagine this will see some rough use (cant imagine why! ) that would suck if they folded over. Maybe is just me, but Id probably over beef things up haha | |
Age : 57 Join date : 2013-12-21 Points : 4806 Posts : 744 Location : Salem Illinois
| Subject: Re: Mud bash jeep for local mudrun April 22nd 2017, 11:01 am | |
| - TheBeal wrote:
- So, it might be wise to reinforce the spring shackles. I imagine this will see some rough use (cant imagine why! ) that would suck if they folded over. Maybe is just me, but Id probably over beef things up haha
yup, square tube welded inside the shackle as a spacer... Reduces the length that can bend. It's all about leverage. | |
| Subject: Re: Mud bash jeep for local mudrun April 23rd 2017, 1:16 am | |
| - Lawren Wimberly wrote:
yup, square tube welded inside the shackle as a spacer... Reduces the length that can bend. It's all about leverage. like this? - mightyraze wrote:
- Sweet cutouts!
thanks it was my first time using a plas cutter | |
| Subject: Re: Mud bash jeep for local mudrun April 23rd 2017, 1:21 am | |
| Had to replace awd transfercase with a 4x4 transfercase still has a miss but low lock takes alto of stress of the little 4.3 v six fun van | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5097 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Mud bash jeep for local mudrun April 23rd 2017, 8:24 pm | |
| My wife wants one of those AWD Astro vans. Good to know it has more uses then just driving on pavement, LOL. | |
| Subject: Re: Mud bash jeep for local mudrun May 19th 2017, 12:01 pm | |
| I don't see a problem... just clean the drums up with a wire wheel and it should be good to go...
HAHAHAHAHAHAHA! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Mud bash jeep for local mudrun May 21st 2017, 1:12 am | |
| Yeah, I'd have a lot of new things hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
