| Li'l Red 1 | |
+22SebastianAlbrecht darkside0914 Buck richie thomas Dave.MTD Double W Cross Ranch Crazy_Carl biggasmowers HILLBILLY RICH BriggsBandit99 Lawren Wimberly TheBeal prancstaman mr.modified tater195 Warren Evans RichieRichOverdrive MatthewD AllisKidD21 MightyRaze Doug CraftsmanQuad19 26 posters |
| Subject: Re: Li'l Red 1 June 24th 2017, 12:52 am | |
| Little set back tonight. Shot the red to the grill part. Looked great, then I hit it with the gloss and the black peeled. I'm sanded back up and ready to hit the black again. | |
Age : 57 Join date : 2013-12-21 Points : 4806 Posts : 744 Location : Salem Illinois
| Subject: Re: Li'l Red 1 June 24th 2017, 1:25 am | |
| DOH! Enamel over latex? | |
Age : 49 Join date : 2016-09-06 Points : 15676 Posts : 10987 Location : Oklahoma
| Subject: Re: Li'l Red 1 June 24th 2017, 4:09 pm | |
| Enamel. It's moving along...
| Subject: Re: Li'l Red 1 June 24th 2017, 4:44 pm | |
| Its looking great so far mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Li'l Red 1 June 24th 2017, 5:56 pm | |
| now ya need to paint the rest of it.... DOH! | |
| Subject: Re: Li'l Red 1 June 24th 2017, 6:12 pm | |
| Lol, the rest is that color. Its just dirty from the past 2 rides. | |
| Subject: Re: Li'l Red 1 June 25th 2017, 10:32 pm | |
| That looks really good mighty! Im loving the look! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Li'l Red 1 June 25th 2017, 10:53 pm | |
| Thanks! I plan on repainting the red part of the hood in the future.
| Subject: Re: Li'l Red 1 June 26th 2017, 2:53 am | |
| awesome lines brotherman... lovin the retro feel | |
| Subject: Re: Li'l Red 1 June 26th 2017, 10:43 am | |
| Thanks! I had the hood laying in the shed for another project maybe and was curious what it would look like on the tractor. Liked it so much I went for it. Came out better than I thought. Just need to finish the headlights and make a new bumper. | |
| Subject: Re: Li'l Red 1 June 26th 2017, 4:44 pm | |
| Got any ideas as far as bumper design mighty? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Li'l Red 1 June 26th 2017, 9:47 pm | |
| Not at this time. I do have the bumper from Sasquatch before build off. I might look into that... not sure. I would like something more beefy maybe. I did get around and fixed the transaxle today. Turned out to be an easier fix that I expected. I had 6 bolts that pulled free. Looks to be from twisting. I need to work on that problem This transaxle only has 3 mounting points. One on each axle end and one by the shifter. I threaded one of the holes on the other side for a future brace so I have 4 full points of contact on each corner. I drilled through the bolts that were popped out and put in 1/4 bolts with nylon nuts and washers on each side for support. Some pix... Bumper I could use. The hole i threaded out. The 6 bolts needed replaced. I thought it was safer to drill out and sandwich the halves than to try to thread it out bigger possibly cracking the case. It's now officially a good guy now. This thing has a whole new seat presence now with the older hood. I like the new feel!
| Subject: Re: Li'l Red 1 June 27th 2017, 9:40 am | |
| Oh, forgot to mention. I figured out my shifting problem. Bolt on the shifter arm came loose. LOL! | |
| Subject: Re: Li'l Red 1 June 27th 2017, 2:24 pm | |
| She looks mean woth those headlights in there. And I still love that Autobots magnet! Hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Li'l Red 1 June 27th 2017, 6:25 pm | |
| It does look mean from some angles with the headlights in. I am having to fab up a new bulb mount for one of them. It was missing. Also, I did get one drop oil out since I redid the bolts. If that is all, I probably have a small blow out in there on the rtv. I'll check that out this fall when I take it apart to check out the doc locker. Make sure no set screws are coming loose. I had one bent bushing I had to try to fix. I think it is holding well.
| Subject: Re: Li'l Red 1 July 2nd 2017, 7:57 pm | |
| This photobucket stuff pisses me off more and more each day. I will fix the images on this thread soon. | |
| Subject: Re: Li'l Red 1 July 2nd 2017, 9:59 pm | |
| Got an inch and a half rain in the past 24 hours. I thought I would hit the mud hole before the slop got too deep. Drove back there with Red and it was dry. It's just too dry right now. The ground soaked it up too fast. On another note, what is with me and routing my belts wrong lately. On the way back I started smelling that burning rubber smell we all hate. Took a look under the tractor and sure enough, wrong side of my tensioner pulley. On the bright side, my shifter rod got polished. | |
| Subject: Re: Li'l Red 1 July 3rd 2017, 8:45 pm | |
| Images should be back now... | |
| Subject: Re: Li'l Red 1 July 5th 2017, 12:39 am | |
| Man I need to start recording some mini-romps that I take out back. Rode back to the empty lot to see if there was any good mud back there after the 3 inches of rain we got last night. NOTHING! just a little surface mud. Man I need to brace this frame up. The more I ride it in the rough stuff the more it twists. | |
| Subject: Re: Li'l Red 1 July 5th 2017, 1:14 am | |
| - mightyraze wrote:
- Man I need to brace this frame up. The more I ride it in the rough stuff the more it twists.
Break out the angle iron! Hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
| Subject: Re: Li'l Red 1 July 7th 2017, 9:10 pm | |
| New hood looks pretty good man! I like it | |
| Subject: Re: Li'l Red 1 July 7th 2017, 11:21 pm | |
| Thanks MatthewD! I like it a lot! Welcome back. Long time no see! | |
Age : 22 Join date : 2016-10-29 Points : 7222 Posts : 4020 Location : Lewisburg, KY
| Subject: Re: Li'l Red 1 July 7th 2017, 11:43 pm | |
| Hey, is that a MTF sticker I see? Didn't know you were on there, lol. The Murray is lookin spicy! I really gotta get painting some time lol | |
| Li'l Red 1 | |
