| What is this box ? | |
sadeoo7 Member
Age : 25 Join date : 2014-01-14 Points : 4271 Posts : 276 Location : Montreal Canada
| Subject: What is this box ? October 9th 2016, 11:45 pm | |
| hi, i found this box in my roper rt16 i think it is related to the starter generator ? is it some kind of regulator/rectifier ? thanks for any info ! " />" /> also does anyone have any documentation on how to hoockup the charging side of a starter generator. | |
| Subject: Re: What is this box ? October 10th 2016, 1:52 pm | |
| Maybe it's a cut out for the starter generator, so when you stop turning the generator it doesn't act as a motor and run down the battery. I don't know too much about them. You might find some diagrams or something if you google your engine or tractor. | |
| | | MatthewD Veteran Member
| | | | sadeoo7 Member
| Subject: Re: What is this box ? October 10th 2016, 8:24 pm | |
| - mr.modified wrote:
- Maybe it's a cut out for the starter generator, so when you stop turning the generator it doesn't act as a motor and run down the battery. I don't know too much about them. You might find some diagrams or something if you google your engine or tractor.
i dont think so because the satrer generator has 2 connections one for the starter and i assume the other one for the generator... | |
| | | AllisKidD21 Moderator
| Subject: Re: What is this box ? October 10th 2016, 8:51 pm | |
| That there is the voltage regulator. It pretty much controls where power goes and when (lights, starter generator, PTO clutch, etc.) Old farm tractors and automobiles have them as well, before computers did the job. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | sadeoo7 Member
| Subject: Re: What is this box ? October 10th 2016, 8:53 pm | |
| ok so it hooks up to the sarter generator ? does anyone know how to wire up a starter generator ? thanks | |
| Subject: Re: What is this box ? October 10th 2016, 9:12 pm | |
| I'd have to look at how it's set up on my Case because I can't remember exactly which terminals go with which. But I'm sure someone on here can help you out. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 61 users online :: 1 Registered, 0 Hidden and 60 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 6:59 am |
