| Project John Deere Sabre (a.k.a. the green hornet) | |
TheGreenHornet Member
Age : 23 Join date : 2016-04-16 Points : 3421 Posts : 227 Location : Indiana
| Subject: Project John Deere Sabre (a.k.a. the green hornet) May 27th 2016, 4:47 pm | |
| So i started this project out of an old John Deere Sabre Garden tractor. Originally it was a hydrostat, but it shouldnt be too hard to convert to gear drive.(if im wrong, someone please tell me now before i get too far into it) As of now any actual progress has been halted by the complicated mess of linkages, springs, pulleys and everything else John Deere stuck under that tractor. i have been working at clearing it out. For an engine, i am putting an 83 briggs 11hp. there is a 2 gallon fuel tank underneath the seat (anyone have any suggestions for fuel pumps?) There used to be a 21 hp kohler command in there, so there is plenty of room for my small single cyl. the steering is the heaviest i have ever seen on a lawnmower. The "pie slice" gear( or whatever its called, im sure most of you know what im talking about) is exactly an inch thick. it has a tierod to each tire and a cast iron front axle with bearings. Anyone have any suggestions? Im gonna need help with this So any help would be greatly appreciated I was going to put a peerless 820 under there, but i have yet to find one. Thanks TheGreenHornet (at this time I do not have pictures, The mower is at another location. Next time im there i will be sure to take some pictures so you guys have some visuals) | |
Age : 34 Join date : 2013-11-02 Points : 7171 Posts : 2910 Location : New Jersey USA
| Subject: Re: Project John Deere Sabre (a.k.a. the green hornet) May 27th 2016, 5:01 pm | |
| There are small electric low pressure fuel pumps you can get but I think most people use vacuum fuel pumps. Pretty cheap. $25 maybe for an aluminum one, probably $10-15 if you get a throw away plastic one. You just need a vacuum source somewhere on the engine. Either put a port in the crank case, or in the intake manifold. Then just stick the lines on and your good. Pumps on ebay, bmikarts.com, probably amazon, or whatever your favorite website is. | |
| | | | mowerheadder New Member
Join date : 2016-04-28 Points : 3161 Posts : 20 Location : New Jersey
| Subject: Re: Project John Deere Sabre (a.k.a. the green hornet) June 7th 2016, 5:24 pm | |
| Howdy, here's a video, dose not explain much and it already has an adapter but maybe it'll help you....Now I've never done this myself just saying. I really dislike JD, they make tons of stupid designs, I have a Scotts(MFG by JD) and an RX73, RX 73 tons of mechanical issues and the Scotts is just gross. Kohler command is stupid thank heavens you don't have one they'r a mess. Stick with Briggs. As for your tranny issue, that's a bit of an issue. Asuming you have a welder that will make setting up linkages and stuff eaiser if not, well your kinda screwed. Just rob another tranny out of another mower or purchase one online for around 150+. Guessing its vertical engine shaft, you could do a custom drive train like most guys do, peerless 700 and such. Just check out youtube and the drive train section here any more specific Q's just ask. And if you mean converting a hydro transmission to a gear tranny, I've never heard of that. Good luck mate! https://www.youtube.com/watch?v=DjRFtz-qwwcOn another note, would someone explain how the vacuum is created in a mower engine? Just a simple break down will do. | |
| Subject: Re: Project John Deere Sabre (a.k.a. the green hornet) June 10th 2016, 5:20 pm | |
| Thank you for the vid. Yes, i agree. John deere really sucks. so does kohler, for that matter. i would have replaced it with a briggs anyway. the kohler had too many wires and cables and such i really did not want to mess with it. Unfortunately for me, im on a very tight budget. This sabre was really the best out of all of them. my other option would have been a craftsman LT4000 AWS with a 6spd peerless 930. It had a stamped frame though and pretty light duty steering and axles. (The mowers were both free, my buddy (craftsmanquad19) took the craftsman. He has the twin to the engine that is going in mine) Yes, i have a welder(at least access to one) right now im pretty occupied with tearing out the hydrostat pedals and all the linkages. i will use the clutch pedal and the forward pedal, but to make things simpler i am tearing them out and creating more simpler designs for them so that there arent cables and ***** going everywhere. Once i find an 820 (it needs to be an 820 because i have hubs for 1" axles and the next step down, an 8o1 has 3/4" axles. i dont wanna get new hubs and i wanna keep the original rims. I have tires for them already. Thank all for your advice | |
