 1997 Murray's 1989 mustang GT build
6 posters
1997 Murray's 1989 mustang GT build Empty
PostSubject: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 7th 2016, 12:41 pm
Sooo if you guys have been wondering why I'm not doing much on my build-off tractor, here is why. I bought this car with a seized motor for 1000 a few months ago.
1997 Murray's 1989 mustang GT build Win_2032
1997 Murray's 1989 mustang GT build Win_2033
stock engine bay.
1997 Murray's 1989 mustang GT build Win_2034
Seized motor, snapped the crankshaft and broke the block.
1997 Murray's 1989 mustang GT build Win_2035
1997 Murray's 1989 mustang GT build Win_2036
pulled the motor out of the LTD II.
1997 Murray's 1989 mustang GT build Win_2037
painted it up, new water pump, converted to SEFI.
1997 Murray's 1989 mustang GT build Win_2038
installed in the car with the AOD trans behind it.
1997 Murray's 1989 mustang GT build Win_2039
1997 Murray's 1989 mustang GT build Win_2040
1997 Murray's 1989 mustang GT build Win_2041
1997 Murray's 1989 mustang GT build Win_2042
Now I just need a serpentine belt and 13 quarts of ATF and I need to put on the upper intake manifold and mass air meter. And I could hook up the mufflers I guess.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 8th 2016, 10:31 pm
I got her running today. Wow this car is fast. just with stock components it's amazing, I guess I'm not used to small cars with big engines. I would probably loose to anyone I go up against, but it's plenty fast for me.
1997 Murray's 1989 mustang GT build Win_2043
1997 Murray's 1989 mustang GT build Win_2044
1997 Murray's 1989 mustang GT build Win_2045
1997 Murray's 1989 mustang GT build Win_2046
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 8th 2016, 10:34 pm
Here is a ***** vid for you guys. I wish I had a better way to take videos than with my laptop.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 8th 2016, 11:53 pm
Im all over fox bodys, but only to stick a chevy motor in them... Razz
Sweet project, and great job on the conversion. i smell mods in the future
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 9th 2016, 9:00 am
Nice Car! Looks like the conversion went well.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 9th 2016, 10:40 am
Nice deal. Is that the intake plenum off the old motor? What's the blocks pretty similar?
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 9th 2016, 11:07 am
Yeah the blocks are basically the same, I had to do some mods to fit the roller cam and lifters, the only difference is the old block has a two piece main seal, and there is 15lbs more material around the mains in the block, so it's stronger. The intake is from the old motor.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 11th 2016, 12:17 pm
I got tabs and plates on it!
1997 Murray's 1989 mustang GT build Win_2047
I just need to weld up the exhaust system and then I can drive it.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 11th 2016, 9:18 pm
Dont get yourself into to much trouble! Cool
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 11th 2016, 9:30 pm
yeah, I almost crashed today coming home from work, back end got away from me on the highway and I actually went off the road into a gravel parking lot which happened to be there, and I recovered and got back on. Here is a better vid of the car running.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 12th 2016, 3:54 am
Sounds good. But yeah, try to keep it out of the fence and not get too hyped up. I have the same issues....
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 12th 2016, 10:16 pm
Thanks guys! I am having some issues with the thermostat not wanting to open, it will heat up to 270 degrees and then stay there for 5 min and then it will suddenly drop to around 230. (maybe my factory gauge is inaccurate, I wouldn't be surprised) SO I'm going to look into that. Also, my heater core burst so I bypassed it. At least now my carpet won't freeze, since it has been marinating in coolant.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 13th 2016, 12:50 am
Cool car you got. 89, should be considered a classic by now, it being over 25 years old. Those cars was always quick just because they are light, around 2500 lbs or so, the weight should be on the driver door jam on the sticker. In my day everybody wanted the 5 speed GT's, just so they can chirp the tires changing gears, LOL. The 302's was always a nice little motor, but when they came out with the SFI (sequential fuel injection) with the tunnel ram intake, which is what you got on top, really made the difference. Have fun!!
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMarch 13th 2016, 4:38 pm
Yeah, this car supposedly weighs 3050 lbs. I want to convert to 5 speed, this one is the 4 speed AOD automatic.
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeApril 5th 2016, 4:36 pm
Finally got the heater core replaced. And I painted and then sanded the high spots on the little intake callout. 1997 Murray's 1989 mustang GT build Win_2018
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMay 6th 2016, 12:38 pm
So I guess I didn't update this, but I broke the oil pump driveshaft. And screwed the motor over. I got a short block from a 1990 stang, and put a ford motorsport z303 cam in it. New lifters and pushrods, new melling oil pump and driveshaft. Got it back together and driving, runs good, but my fuel economy dropped a bit...Laughing but the exhaust sounds nice. Cool Twisted Evil
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMay 7th 2016, 6:20 pm
You swapped the heads off the blown up engine? How long did all that take?
PostSubject: Re: 1997 Murray's 1989 mustang GT build   1997 Murray's 1989 mustang GT build Icon_minitimeMay 7th 2016, 8:11 pm
so this is engine #3 now?
» 1983 Mustang, retirement car build or; The last car I'll ever build
» 1989 craftsman mud tractor build up
» 1989 lawnboy [2018 Build-Off Entry]
» 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry]
» trash find murrays
