| redzz02 dynamark build | |
+91997 Murray rarbaugh07 redlinemotorsportts craftsmancole mr.modified MatthewD 802 Customs Doc Sprocket redzz02 13 posters |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: redzz02 dynamark build August 18th 2015, 9:54 pm | |
| heres some of an update i got the front axle all gear oiled up and sealed, i have the exhaust done as of today. the to do list: finish intake make fuel tank make shifters add brakes finish frame(waiting on metal) dash board paint heres some pictures for now the little tabs on the bushings inside the transaxles, you have to make sure they are down in the groove if they are up like this, your going to have a problem front axle all oiled, greased, and sealed some mock up two inch side pipes not welded to the headers yet | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: redzz02 dynamark build August 19th 2015, 8:38 pm | |
| I can't wait. Looks like one of the best refined 4x4 mowers out there with frame bracing | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5099 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: redzz02 dynamark build August 21st 2015, 7:39 pm | |
| Looking good!! Nice exhaust, going to look and sound mean coming out the sides. Are you running 2 shifters, one for each gearbox? | |
redzz02 Site VIP
Age : 30 Join date : 2010-05-12 Points : 6379 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: redzz02 dynamark build September 2nd 2015, 11:20 pm | |
| yes im gonna run two shifters, one for the front axle and one for the rear, and also an engagement lever for the front axle belt, which im over here trying to figure out how im gonna run the shifters, i think im gonna have to use cables instead of rods | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build September 2nd 2015, 11:58 pm | |
| Got a tip for you on running cables for your gearboxes. The drive cables off of weedwackers work great. There like 4 times as thick as speedo cable which means on the ends, you can weld something to them. I used this idea on my Jeep to lock the front axle up from inside the cab which is a push and pull lever. Never had a problem with it for over 4 years.
You pull the cable out of the tubing of the weedwacker and the plastic liner too. And wallah, You got a heavy duty shifter cable. Making the ends should be easy, keep in mind, a shifter cable for a car. | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build September 21st 2015, 11:57 pm | |
| Wow!! The pic with the tires on it, that looks mean!! Cool shifter setup too. | |
| Subject: Re: redzz02 dynamark build September 22nd 2015, 12:51 am | |
| big big fan of this thing. looks so agressive. cant wait to see it dominated the mud. are two shifters and third the brake?
Deluxe66 Member
Age : 47 Join date : 2014-05-23 Points : 3964 Posts : 120 Location : Finland
| Subject: Re: redzz02 dynamark build September 22nd 2015, 5:32 am | |
| This project is really interesting. Frame and other parts looks durable. I am following also this built. | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build September 23rd 2015, 8:54 pm | |
| Thanks guys and redline the shifter on the left controls the engagement of the front axle, the middle lever controls the rear axle shifting, and the one on the right controls the front axle | |
redzz02 Site VIP
Age : 34 Join date : 2013-11-02 Points : 7172 Posts : 2910 Location : New Jersey USA
| Subject: Re: redzz02 dynamark build September 23rd 2015, 10:08 pm | |
| Very neat setup. The bracing between the two transmissions looks good. | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build September 24th 2015, 10:51 pm | |
| - redzz02 wrote:
- Pranayama yes I made it and thank you modified
Pranayama ? LOL! | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build September 25th 2015, 1:28 am | |
| Lol wow that's cellphone auto correct for you and not reading before you hit send does | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build November 7th 2015, 10:20 pm | |
| alot has changed since the last update, it now runs, drives, and all in all is almost complete. now its all the little things like bumpers, wiring, cleaning sharp edges and welds, and finally paint fuel tank complete battery tray the lady friend helping with the buildmaking bumpers front bumper almost complete now since my first video of the tractor moving i have swapped the engine pulley from a 5 inch down to a 3 inch and moved the idler pulley around and the belt is almost perfectly engaging, things left to do -rear bumper -rear lights -finish wiring lights, and sending unit -replace temporary shift levers -paint | |
| Subject: Re: redzz02 dynamark build November 8th 2015, 1:07 am | |
| Love that gas tank, even a sending unit, COOL! The front bumper looks great too. You're definitely turning up the heat. I got something planned this weekend, should be cool to see for mine. | |
danielersrail New Member
Age : 34 Join date : 2015-07-10 Points : 3434 Posts : 5 Location : Auburn
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build November 9th 2015, 11:07 pm | |
| prancstaman-thanks i wanted to do something realy cool with the dash and the sending unit but i just dont have enough time, and thank you danielsrail im trying my best | |
| Subject: Re: redzz02 dynamark build November 9th 2015, 11:36 pm | |
| Wait wait wait........There's no women helping build my projects? Is that even build off legal???? Looks good though. The tractor, you know. | |
redzz02 Site VIP
| Subject: Re: redzz02 dynamark build November 10th 2015, 12:02 am | |
| Hey now hey now.... Don't blow my cover I haven't built any of the mower she's been doing the whole thing hahaha | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5756 Posts : 1993 Location : Northern Ireland
| Subject: Re: redzz02 dynamark build November 10th 2015, 2:53 pm | |
| That looks really good! I'm sure you're giving the other build-offers alot to think about | |
| Subject: Re: redzz02 dynamark build November 10th 2015, 8:44 pm | |
| - redzz02 wrote:
- Hey now hey now.... Don't blow my cover I haven't built any of the mower she's been doing the whole thing hahaha
Oh ok, I won't say anything. | |
