| pulley material | |
N1ck Member
Age : 24 Join date : 2014-06-08 Points : 3905 Posts : 74 Location : North Central Arkansas
| Subject: pulley material March 4th 2015, 11:04 pm | |
| I was wondering why there are different materials like aluminum, cast iron, steel and others. thanks | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
| Subject: Re: pulley material March 5th 2015, 7:35 am | |
| Application, really. The cast zinc and cast aluminum pulleys are light duty. They are rated for FHP (Fractional HorsePower) applications and are not intended nor recommended for uses where they are driven by 1hp and up. When I see guys use them on mowers, I cringe a little. Some folks get lucky, but for the most part, it is a failure waiting to happen.
Steel and cast iron are for heavier duty applications, like ours. | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
| Subject: Re: pulley material March 5th 2015, 11:22 am | |
| - Doc Sprocket wrote:
- Application, really. The cast zinc and cast aluminum pulleys are light duty. They are rated for FHP (Fractional HorsePower) applications and are not intended nor recommended for uses where they are driven by 1hp and up. When I see guys use them on mowers, I cringe a little. Some folks get lucky, but for the most part, it is a failure waiting to happen.
Steel and cast iron are for heavier duty applications, like ours. I ran a 4 inch aluminium pulley on a mower for years and nothing ever happened. I don't think it was cast aluminium though | |
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: pulley material March 5th 2015, 2:55 pm | |
| When you wear out a cast aluminum or zinc pulley, it will take your belt with it... Trust me. I'm speaking from experience. I've destroyed a stamped steel pulley too (took over 10 years), though, so maybe it is a "me" thing... | |
| | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4953 Posts : 919 Location : Defiance, Ohio
| Subject: Re: pulley material March 5th 2015, 7:21 pm | |
| I would have to say the ultimate pulley would be brass >.> or bronze nice and heavy like cast iron but strong like steel. Could run at a higher rpm than cast iron the pulley on the massey is rated for something around 3200 rpm. Stamped steel is pretty nice but I think itd be prone to separating at the welds after time. Haven't seen a turned steel pulley in a while... | |
| | | crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4895 Posts : 412 Location : livingston texas
| Subject: Re: pulley material March 5th 2015, 7:34 pm | |
| Im using the pulleys off my deck, i think their steel. So far no problems except slippage when wet | |
| | | Murray modder Member
Join date : 2012-11-23 Points : 4803 Posts : 356 Location : Somewher in Va
| Subject: Re: pulley material March 5th 2015, 9:43 pm | |
| With cast Aluminum pullies, or at least the few I've *tried* to run, the edges (on the tips of the V groove) Tend to come apart after a few hours on them. Those edges are almost like serrated blades to that belt. | |
| Subject: Re: pulley material March 6th 2015, 7:24 am | |
Steel and cast iron are for heavier duty applications, like ours. I ran a 4 inch aluminium pulley on a mower for years and nothing ever happened. I don't think it was cast aluminium though Well- I DID say: - Doc Sprocket wrote:
- Some folks get lucky,
| Subject: Re: pulley material March 6th 2015, 9:19 am | |
| @Moose- Glen's has turned steel pulleys fyi | |
| | | | | pulley material | |
| Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests
