Hey guys, I'm trying the build off this year (even though I'm slightly crippled right now ). I wrote today's date in the pictures but my phone isn't cooperating. I'll have the pictures up by tomorrow morning at latest. *Edit* I got the picture working and I am in the process of uploading a video to YouTube. I will post the video on here when it is done.
Have/on mower: Ford YT16 23hp Kohler vtwin MST206 with 205 case stock clutch system (minus spring) 7" front pulley
Mower needs: 4 1/2" - 5 1/2" rear pulley Belt Frame extended and stiffened Front axle and spindles welded Rims and tires (rear) Skid plate Bumpers front and back Rust repair Hood mounts Wiring Holes drilled for mounting engine Transaxle supports Paint Steering Probably more things I forgot to list here.
Age : 25 Join date : 2013-04-05 Points : 4964 Posts : 661 Location : New Smyrna Beach,Fl
I dont have the google plus and youtube accounts joined. all my videos and subscribers are on CraftsmanCole while the video posted to Craftsman Cole (google plus).
it has a 25hp carb on it which is slightly bigger so it will probably make around 25. The 25 hp motor needs too much work to be bothered with right now, thats the reason I'm using the 23hp.
I just found out that the sound stopped working in my video I made. I'll have to redo that soon. Also is it ok for me to enter multiple builds into the build off?
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5154 Posts : 1068 Location : New jersey
Yeah you can enter more then one
Alright thanks.
They usually achieve more horsepower through bigger bore and stroke. 23 HP does sound NICE! My 11hp flatty loves to stall in like 3rd gear if I dump the clutch at low rpm.
I decided to use the 25 horse block because it is 725cc vs like 664cc or something like that. There's no replacement for displacement Plus I got the hubs cut out today so she's sitting on all fours now!
Here's the list of things I still have to do to get her done:
*Finish steering linkages *Finish welding transaxle mounts *Pressure wash and pain the Kohler's block *Assemble and torque down the heads and valves *Clean the carb again and fix the leaky bowl *Exhaust *Build a fuel cell *Cut a hole and mount the cell under the fenders *Make/fix the grille *Throttle *Clutch spring *Belt *Maybe a front bumper (I'll have to cut off my hood mounts and redo all that) *Brakes would be nice *Lights *Strip all paint *Fix any and all rust *Paint *Reassemble the body
There might be a few things I forgot but that is pretty much it.
Here's some stuff I forgot to post from about 2 1/2 months ago (oops ) I'm probably going to actually start to work on her again after I move all the crap that is now in the way.
Doing a bit of grinding before welding the spindles on
Awesome picture of me welding the brackets to mount up the hood
Fitting the hood after welding
I moved stuff out of the way and found all my motor parts for this but that took up all the time I had to work on this today. Plus I'm thinking about finding some of those lights that people put under their cars for under the hood to look like that picture of me welding.
Age : 34 Join date : 2013-11-02 Points : 7171 Posts : 2910 Location : New Jersey USA
Those front axle extension deals are neat! Gives a sort of suspension look without all the hassle. Light behind the grill would be neat too. Any ideas on paint colors yet?
I think I want it to be Ford blue and silver two tone instead of blue and white.
