 Northern Tool mechanical kart brake caliper-anyone using it?
YotaTruck
Northern Tool mechanical kart brake caliper-anyone using it? Empty
PostSubject: Northern Tool mechanical kart brake caliper-anyone using it?   Northern Tool mechanical kart brake caliper-anyone using it? Icon_minitimeFebruary 11th 2015, 6:59 am
Found this recently:
http://www.northerntool.com/shop/tools/product_200323386_200323386
Looks like a pretty simple solution. I'm lucky enough to have a tractor with a dedicated brake pedal on the right, so I can just hook up a linkage and be done. It looks like it's simple push or pull operation. It works with this disk which is a 1" keyed bore (will be going on a Peerless 820):
http://www.northerntool.com/shop/tools/product_200321706_200321706
This is going on a work tractor-10MPH would be crazy fast, so I think that even though these are meant for go-karts they'll work and last. I'm going to need two because I don't intend on locking the axle-it would tear up the grass too much. Any suggestions on how to actuate both at the same time? I was thinking of using a cable.
» Go Kart rear brake/sprocket hub issue
» Trans Axle Input Shaft Brake (Pinion Brake)
» Brake idea, using existing brake.
» Northern Ohio
» Hello from Northern Ireland
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
