 MatthewD's Westwood T1200 Rally Mower
802 Customs
10 posters
MatthewD's Westwood T1200 Rally Mower - Page 3 Empty
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 19th 2015, 5:38 pm
I just found the part number out. It's 695708 for reference. I'm going to my local lawnmower store tomorrow to get one.
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 20th 2015, 12:28 pm
Got the starter gear and got engine running for first time in 5 years. Been sitting in my shed under my wood pile (basically holding it up). I nicked the coil from my 12hp (she had points and I couldn't get flywheel off so just snipped wires and put other coil on). I think I have the carb adjusted correctly, I don't have a proper mount for the tank yet so it's a little hard to keep a constant flow of fuel to the engine.
I'm wanting to reflect the look of the craftsmans and I was thinking about cutting my dash down to mimick the look (see pic below).
MatthewD's Westwood T1200 Rally Mower - Page 3 Dash10
What do you think??
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 23rd 2015, 4:34 pm
Got some updates but will get onto them in the next couple of days Smile
I'm at a loss on where to go with regards to steering and front axle. Should I go direct steer or mod the original steering to fit?
Also how should I go about mounting the front axle. There are 2 axle hangers/carriers, one is bolted on and the other is part of the front of the chassis. Should I cut the front one off and weld it onto the front and then bolt the back one on? If so, where should I cut??
Sorry for so many questions, this is my first time, really, working on a lawn tractor. We all have to start somewhere!!
jonnya
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 23rd 2015, 4:45 pm
I'm also pretty new to mower modding. I;d keep it simple for your first build. Steering can get pretty heavy with direct linkage, It gets lighter as you are moving, which is good for a speed machine, but a right PITA if its a crawler type thing. My hot rod mower uses a slightly modified, but mostly standard arrangement. Works ok but there is room for improvement. My tip here is to not work on the mower steering with the chassis upside down. I did this and spent a whole day making a steering system which worked really well apart from the fact that if you steered right it went left and vice versa! I think it is moments like this which swearing was invented for! Double check everything!
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 23rd 2015, 5:18 pm
Okay. I suppose I'll cut bits out of the old frame to do with the steering and then weld onto the new frame.
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJune 29th 2015, 5:12 pm
delete
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJuly 1st 2015, 6:22 am
delete
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJuly 7th 2015, 11:56 am
delete
PostSubject: Re: MatthewD's Westwood T1200 Rally Mower   MatthewD's Westwood T1200 Rally Mower - Page 3 Icon_minitimeJuly 18th 2015, 5:56 pm
I'm out of the build off. I picked up another Westwood T1200 and a spare one (minus engine and rear axle) for £160. It will be my tractor now but won't be as heavily modified as my custom one. It needed far too much work.
Sorry, but I'll not be finishing this year.
» '86 Westwood T1200
» Westwood t1200 fluid drive
» Westwood T1200 Offroad/Utility tractor
» Cool Lazer/Westwood 6x6 mower
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2015 Archive-
