| MatthewD's Westwood T1200 Rally Mower | |
+6kawasaki220 redlinemotorsportts mr.modified 802 Customs Doc Sprocket MatthewD 10 posters |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 9th 2015, 9:28 pm | |
- you pay for what you get in the lighting world.
Except me, I'm special and get my stuff for free. That roll bar would be neat for a bumper. Even if you wanted to cut it up and weld up something different, some nice bends there and all the same size tubing. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5755 Posts : 1993 Location : Northern Ireland
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 12th 2015, 6:20 pm | |
| 12/03/15Small update, done some planning of my new frame and working out the pulley and belt system. I also opened the Carburettor up and rubbed it down ready for reassembly and paint! 14/03/15Afternoon all, Got a Small Update! I put the Carburettor back together and painted it Got a run down the side of the bowl, but nothing too bad There are lots of other runs as well but the carb will be hidden under the hood. | |
Guest Guest
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 14th 2015, 1:31 pm | |
| if u have the time and tools id take that carb there where intake bolts to the head i would go on ahead and port out that rough spot there it might create a small low spot for it not to flow right and might cause some power lack and lag im not 100% sure on this but looks rough lol |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 14th 2015, 6:20 pm | |
| Yeah I do plan on porting the intake of the carb out because it is actually an 8hp carb, the engine I'm using is a 12hp. It isn't as rough as it looks in RL though but I'll still try and port it a little. | |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 17th 2015, 2:58 pm | |
| Right, I'd like your feedback on this as I'm a lil stuck.
I have 18 inch ags on 8 inch rims that I'd like to use for the back. I think I can get my hands on 8 inch rims for the front aswell. So my question is, do I:
go with 18 inch ags on rear, 18" turfs on front
OR
22 inch knobbys rear and 18" ags on front?
Please let me know what you think, desperately need your feedback on this as you guys have the experience. | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5448 Posts : 1311 Location : NW USA
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 17th 2015, 6:17 pm | |
| I think 22" knobbies on rear and 18" ags on front would work the best, but if you don't have the money for knobbies just ags should work fine for the rear. | |
Guest Guest
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 18th 2015, 3:13 pm | |
| i know the ags in our area are higher then the knobbies which is why i went knobbie due to them being cheaper and on amazon theres different sizes on the knobbies for 8" rim too i know ags are ok there pretty good but hard to keep cleaned out to bite down for more traction |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 28th 2015, 12:16 pm | |
| Sorry no updates guys.
I've stopped work on the tractor for the time being, got too many other projects. I'm still in the build off, just don't have time to work on it for a while.
Good Luck to the rest of you! | |
802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3760 Posts : 146 Location : Vermont
| Subject: Re: MatthewD's Westwood T1200 Rally Mower March 28th 2015, 7:53 pm | |
| Ahh yes I can feel you on being overwhelmed with projects. I try to keep one in running order so I can still have fun, and I can still have projects to work on. I try to keep it to one project at a time. I loose interest and parts go missing if I've got all types of sh!t torn down.
Last edited by 802 Customs on March 29th 2015, 11:18 am; edited 1 time in total | |
thewisconsinredneck5160 Member
Age : 25 Join date : 2015-02-16 Points : 3618 Posts : 40 Location : Brookfield WI
| Subject: tire size March 28th 2015, 10:41 pm | |
| - MatthewD wrote:
- Right, I'd like your feedback on this as I'm a lil stuck.
OR
22 inch knobbys rear and 18" ags on front? what was the original tire size because if they are too different they can throw off the angle of the tractor which can be bad for going up or down steep hills but from what is the norm on tractors id go bigger with the back just to keep the angles right | |
jonnya Member
Age : 49 Join date : 2014-08-19 Points : 3862 Posts : 95 Location : Norfolk, England, UK
| Subject: Re: MatthewD's Westwood T1200 Rally Mower April 8th 2015, 1:00 am | |
| Or you could carry out a body raise by packing up the rear transaxle with some box section and use the mowing deck PTO pulley to get power from. Should gear it up a little too. | |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower April 12th 2015, 10:14 am | |
| - jonnya wrote:
- Or you could carry out a body raise by packing up the rear transaxle with some box section and use the mowing deck PTO pulley to get power from. Should gear it up a little too.
Yeah was thinking about that but I would need to lower the transaxle by 100mm (3 15/16 Inches) | |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 12th 2015, 2:38 pm | |
| Finally some progress! I got the frame cut and welded together. I'm using an old rod welder (got it for free so can't complain), My welds aren't great to say the least. I started working on a foot throttle. Basically there will be a washer welded at near enough the enough the end of the rod, leaving just enough room to attach a return spring. Then it will be bolted onto the frame and linked to the engine. I have started to make a fuel tank mount and I got 2 nearly new 15" turfs for the front (they were free ) I'll be using my 18" ags for the rear. I'm out of welding rods at the minute but the plan is to finish welding the frame, fit front axle, then get rear axle mounts done (front and rear axle will be raised up) Do-to list Finish frame Cut off excess metal and brackets from body & finish fuel tank mount Make up seat bracket Finish throttle Make up foot plates Get engine running Lock transmission Electrics Front and rear axles And many more things! | |
jonnya Member
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 13th 2015, 3:41 am | |
| Hi, on a previous post you mention rev counters. I'd go for the analogue one. I bought a cheapie digital one and it's pretty useless if you are using a foot throttle and the revs are continually changing. It can keep up with the change. I guess it would be fine on something with a hand throttle. Can you share the details of the analogue one you have found? I've had a look for one but no joy. | |
jonnya Member
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 13th 2015, 3:22 pm | |
| Right ho, I guess youd have to think about the wiring for this as it's designed for 4-6-8 cylinder engines. Although briggs engines run a wasted spark ignition so maybe would work as per a 4 cylinder? I'm not an expert on electronics so not sure? | |
jonnya Member
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 14th 2015, 10:35 am | |
| I've got one the same as that on my rat rod. I wouldn't recommend one. The display takes a long time to catch up. Only any use on a standard type hand throttle, the ones for constant revs. It's ok for setting up the engine, but no use whatsoever when the mower is in motion. | |
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 14th 2015, 4:39 pm | |
| Right okay. I may not use one at all.
I've decided to use the 8hp flatty. It's been in our family since new and been rebuilt by my dad and uncle and it has a cast iron sleeve. I'm going to run it without the governor since I've done it with a couple of Honda GX's and never had any problems. Would it be better to remove it or just bypass it? | |
Age : 34 Join date : 2013-11-02 Points : 7171 Posts : 2910 Location : New Jersey USA
| Subject: Re: MatthewD's Westwood T1200 Rally Mower June 14th 2015, 5:00 pm | |
| Frame looks ok. Welds aren't horrible, close enough. About the governor, a lot of people like to take the guts out of the engine because they don't want them falling apart inside. I usually take them out, but If you don't want to take the case apart you can hook a spring on the governor rod to hold some pressure on it. I don't see how it could fall apart anyway, I guess if they just lay there loose they can get banging around. | |
Age : 23 Join date : 2013-04-08 Points : 5211 Posts : 913 Location : Central Pa
